Sub-to-Dub's 2017 GTI Sport
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
Sub-to-Dub's Build Journal
2017 GTI Sport
This certainly won't be the most adventurous build journal around but I think it'll be fun documenting my OEM+ mission for the GTI.
I picked up this '17 GTI Sport from Stohlman VW in October 2016 for $22k. This is my first new car and my first Volkswagen. I've always been a Subaru guy (previously drove a '94 Legacy Turbo and a '06 Impreza 2.5i wagon) but the GTIs perfect blend of sport and comfort was too hard to pass up as my daily driver. I've never owned a car with so many aftermarket options and I'm looking forward to the adventures ahead!
Mods/Parts List
Suspension/Chassis/Brakes
VW DriveGear (DG) springs + Bilstein B8 dampers
aFe 29mm front swaybar + MOOG endlinks
ST 25mm rear swaybar + MOOG endlinks
034 front subframe locking kit + ECS rear subframe locking kit
ECS swaybar mounts
Superpro lower arm control bushings
Centric PosiQuiet pads + Zimmerman rotors
ECS brake master cylinder brace (waiting to be installed)
A3 rear subframe harmonic damper
RS3 brake ducts
Shifter/Drivetrain
BFI stage 1 engine/trans mounts
OEM euro short shifter
ECS solid shifter cable bushings
Powerflex dogbone insert (red diesel version)
Dieselgeek metal side-to-side bracket
Dieselgeek shifter shaft bushing kit
Burger Motorsports clutch stop
Clutch bleeder delay valve delete
Clutch pedal spring delete
Wheels/Tires
BBS CO 18x8
Vredestein Hypertrac tires 235/40-18
Black APR wheel bolts
Exterior/Cosmetic
OEM fog light retrofit (pending)
Window tint (Llumar CTX @50%)
OEM euro blindspot mirrors
Color-matched mirror caps
Interior
8" EDM infotainment screen
Helix subwoofer
OEM auto-dimming mirror
DIY weighted shift knob
VW Monster Mats
TravAll cargo mat
Canvasback rear seat cover
Garmin Mini dash cam
Utility/Protection
Evolution Import Ares skid plate
ECS Tunnel Shield
EcoHitch trailer hitch
Yakima roof rack
Small Tweaks/Mods
SC SkunkWerks grounding kit
Snow guard delete
OEM intake block-off plate
COBB ABS module heat shield
EMD billet coolant adapter
MK8 rear control arm aero covers
Osram Night Breaker HID bulbs
OBDEleven Tweaks
Vibration reduction - Deactivated
Reverse mirror dip - On
Soundaktor - Off
Hill start assist - Early
Seatbelt warning - Off
Windows up/down with remote - On
Front amber side marker/white dot - Off
Rear sidemarker - Off
Hot country AC - On
Increased blower speed - On
Past Mods / Reason for removal
034 Motorsports 10mm rear spacers - no longer needed
Dieselgeek super slider - replaced by Dieselgeek side to side bracket
Dieselgeek Sigma Six short shifter - prefer a less notchy shift
Boomba shift knob - got tired of the shape and appearance but do miss the weight
VW Laguna Seca wheels - replaced with other wheels
DAP wheel spacers (15mm/20mm) - not required on new wheels
H&R OE Sport springs - bouncy w/ stock struts, reverse rake w/ TT pads+spacer
Burger Motorsports JB1 - too much clutch slip
Clubsport S muffler - didn't sound good enough of the time
Boomba short shift adapter - pin broke, replaced w/ OEM Euro shifter
Roc-Euro stabilizer bar - issue w/ bolts backing out, replaced w/ OEM
ECS pendulum arm - bearing wore out, replaced w/ OEM
ECS dog bone insert - replaced w/ Powerflex red for reduced vibrations
OEM metal cable shift bracket - fitment issues, replaced w/ OEM
034 dog bone insert - deformed and became less effective, replaced by Powerflex red
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
November 2016
I was thankful the dealer asked if I wanted the bumper drilled. Naturally I decided on using a tow hook mount. I ordered a US Millworks quick release mount and couldn't be happier!
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
November 2016
The Sport's Nogaro wheels were nice but I preferred the Austins found on other years/trims. I sold the Nogaros to a very nice local Tiguan owner and picked up a set of used Austins for $400 and put on some Continental ExtremeContact DWS06s.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
November 2017
Just installed a Boomba Racing short shift adapter. Great price, very easy to install and a great improvement to shift feel; the best kind of upgrade!
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
January 2017
Not really an upgrade but I prefer the size and feel of the standard Golf shift knob. It's certainly not as cool as the golf ball but the materials match others in the cabin and it feels much nicer in the hand. I had to pick up an EDM model since our Golfs only had a 5-speed.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
August 2017
I love my current DWS06s but found the grip under hard acceleration inadequate. I bit the bullet and picked up a set of used Laguna Seca wheels and Continental ExtremeContact Sport summer tires.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
August 2017
Installed a V2 034 dogbone mount adapter. It added some vibration at lower RPMs but feels more solid, helped reduce (but not eliminate) wheel hop, and added back a little "sport" to the GTI equation.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
August 2017
Installed an OEM metal shift cable bracket and Integrated Engineering solid bushings. It was a royal pain getting access without removing the battery but it's possible.
These parts make a very slight improvement in shift feel but it's also nice to know they'll never wear out and are no longer a weak link in the system. I also installed a Sigma shift kit but found it a little too notchy for me so I'm sticking with the Boomba adapter for now.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
September 2017
Just hit 7,000 miles and have had no sutstantial issues (knock on wood!) Ok, maybe a few noises here and there but that's just part of getting used to a new car I suppose.
The only noteworthy thing is that the car occasionally flashes the "key not detected message" even though I can unlock and start the car just fine and the fob has a fresh battery. Also, the 1-2 shift can grind a little during quick shifts.
So far, so good and I am loving the car!
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
September 2017
I realized the other week that the dealer had drilled the rear license plate holes almost an inch too far to the right. I don't know how my OCD didn't catch it sooner!
I ordered a mount that uses two screws to secure the mount to the bumper and the four screws for the plate screw into the mount. It's a similar style to the Volvo one some other MK7 owners have used. This one was about $20, fits great, and feels more secure than before.
Sub-to-Dub
Arlington, VA USA
'17 GTI Sport 6MT
October 2017
I have since uninstalled this mod because the bolts securing it to the tranny came loose and bent. See the post here.
I decided to continue my quest to tighten up the drivetrain with a Roc-Euro stabilizer bar. This replaces the OEM part with the rubber bushing.
Installation was incredibly simple and took about 10 minutes including setting up the ramps and getting out the tools.
Not a massive difference but it seems to have lessened and smoothed out the vibrations introduced by the 034 insert. I've also noticed that starting smoothly in first seems slightly easier. However, I'm not sure if it would make more or less of a difference for someone without a dogbone insert.
Overall I am satisfied: it made a positive improvement to the driving experience and seems like a very well made product.
