Sub-to-Dub
- Arlington, VA USA
- '17 GTI Sport 6MT
September 2021
Project: pad/rotor install, bleed brakes on PP equipped car
Products: Centric Posi-Quiet ceramic pads, Zimmerman rotors, OE hardware
Cost: ~$350
Install time: 4 hours
Difficulty: 2/5
I'm taking a cross-county road trip next month and figured it was a good excuse to do brakes. The car only has 30k miles on it and given the pad material left I probably had 30k more miles left but the dust and noise has been driving me nuts. The replacement parts are nothing special, just OE level stuff but I'm expecting the pads to dust less and remain quiet in all conditions.
This isn't a how-to but here's a quick outline of the tools needed and some tips/observations. The parts and notes below are for a performance pack equipped car.
Required tools/materials:
Installation notes/tips:
This wasn't much different than doing a brake job on any other car. The only thing that was new for me were the rear calipers (which use the caliper piston for the parking brake vs a separate shoe). This means you'll need a special (but inexpensive) tool to get the job done. Most folks probably know these things but here's a list my past self would have found useful before starting this job:
So that's it, just a few thoughts on the job. Overall it was pretty straightforward, just take your time with those rear pistons.
All the parts ready to go. You really only need to replace the rear caliper carrier bolts but I got all new hardware (yes, definitely overkill).
PP fronts. They'll never looks this nice again
The rears were more difficult (at least on jack stands) due to tighter bolt access and having to retract the pistons.
Cost: ~$350
Difficulty: 2/5
- 17mm socket -- lug bolts
- 13mm socket/wrench or M8 triple square-- caliper slide bolts
- Thin 16mm wrench or needle nose vise grips -- to counter-hold the caliper pins
- 21mm socket -- front caliper carrier bolts
- M14 triple square -- rear caliper carrier bolts
- Torx T30 -- rotor set screw
- Socket wrench
- Torque wrench (one that can handle 200Nm)
- Caliper piston retracting tool. I used this model from Amazon
- Wire brush/sandpaper/wheel/etc to clean up the hub faces
- Grease (for caliper pins, shims, back of pads, etc.) Make sure it's safe for rubber if doing the caliper guide pins. I used SIL-Glyde.
- Minimum hardware: rear caliper carrier bolts (4 of N91168901) as recommended by the service manual since they are torque-to-yeild
- (4) front caliper carrier bolt -- N91084901
- (4) Rotor set screw -- N10648301
- (8) Caliper guide pin bolts -- WHT010085
- Anti-seize -- for the hubs
- 11mm wrench -- for caliper bleed nipple
- DOT 4 LV fluid, I used a liter of ATE SL.6
- For the bolts on the front caliper carriers, turn the wheel all the way to one side so you can get a breaker bar and torque wrench in there. I was working on jack stands and there's no way I would have been able to achieve the 200Nm required for those caliper carrier bolts without that extra space to work.
- Remember to open the fluid reservoir cap when retracting the pistons and watch for spillage.
- Make sure to have your parking brake off when doing the rears.
- If you have one of these universal caliper tools, make sure you use the tool labeled "RH". This will allow you to turn the caliper piston clockwise while the tool pushes against the caliber body opposite the piston. Don't be like me and waste time thinking "LH" and "RH" are for the different sides of the vehicle. Doh! The pistons need to be turned clockwise while being pushed in order to retract.
- If the piston boot is twisting with the piston as it retracts try applying a little silicon spray to help it stay put so it doesn't tear.
- For the rear caliper carrier bolts, if you're on jack stands like I was, using a socket wrench with a swivel head allowed me to break the bolts by aiming the tool in front of the strut and out the wheel well.
- The replacement pads came with a wire for the wear sensor. My '17 Sport doesn't need this so I just snipped the wire.
- I wasn't able to get my torque wrench in to tighten the rear carrier bolts so I just snugged everything up tightly.
- If the brake rotor won't come off with a few whacks with a mallet, spray a little penetrating fluid on the hub and in the bolt holes and wait a few minutes. Don't be afraid to really hit it (I had to get out the small sledge hammer for a few).
- Clean and remove any rust from the hub surface of rust before installing the new rotors. It's probably overkill in most cases but why not start with a fresh surface and minimize any chance of vibration?
- I applied a very thin layer of anti-seize to the hub before putting the rotors back on. I know folks have differing opinions on this but given how stuck a few of my rotors were this seemed liked good insurance for future me, just don't over do it.
- Pay attention to the caliper guide pins. My car only has 30k on it but the grease on most of the pins was really dirty and runny (maybe some water got in?). It certainly can't hurt to apply some fresh grease. Whatever you use make sure it's safe for rubber.
- If you're anywhere near the service interval for bleeding the brakes, consider doing it now. A power bleeder make this a 10 minutes job.
- Bed in the pads according to the pad manufacturer. For these pads Centric told me: "make 10 stops from 50mph down to 10mph or so, in relatively quick succession. Being careful not to come to a complete stop during the 10 stops."
