No helper springs here, 7" spring lengthFor those of you running high rear spring rates... assuming you're using relatively short springs, are you using helper springs? Im going through the math and working out ride heights and whatnot.
7" was what I was coming up with... but would be loose at full droop. No silly noises/popping driving around/driveway entraces/etc?No helper springs here, 7" spring length
What he said about the threaded damper body, so spring is never loose at full droop.Mine are 7" too. No surprise, we both have Redshift. On the Redshift coilovers the rear damper body is threaded. So there is no slop at full droop. But overall droop length is reduced.
I'm 950 rear, I think Brad is 700.
Yeah that's correct. The threaded damper acts to provide preload to the springThreaded damper..... so you are essentially limiting droop travel via the damper length, and therefore keeping the spring in compression at all times?
I have no clue on actual droop, I haven't measured. I can check next time I jack the car upInteresting. How much droop travel do you get from ride height? If it was extreme, seems like you could get some weird transitional effects in slaloms and whatnot.
Primarily DD, 1-2 autox a month, right now no HPDE but hoping to do a couple a year starting next year.
My build in general is going for dual use. I'm not strictly STU spec so not trying to make nationals of anything, but I want a build that will be fun and engaging to drive at autox and not have me 4 seconds back or fighting the car without punishing me for DD.
Mods now are stg1, css knuckles, neuspeed rsb, superpro fsb, rs3 LCA bushings, and strut braces. 17x9" wheels coming for autox/hpde duty. Settled on Ohlins over redshift or similar as they seem to be the same balance of comfort and performance.
Yeah if I ever get serious about it I'll swap out the knuckles and install camber plates. Don't think anybody will care locally as long as I don't have both.You're already in XS because of the knuckles. For just DD, maybe a track day and not "Competitive with the a capital C"... I think the Ohlins are overkill. I'm not saying they aren't great, but that's a lot of money to drop, where there's other options that meet those needs. Certainly there will be compromises, like less ability to go stiff on the springs, hard to access damper adjusters, etc. If you just want some pimp dampers, go for it and enjoy.
But... where's the fun (and self-hatred for throwing all your money into a bottomless pit) in that??At least until I realize I should sell my R for like $3k less than I got it for 30k miles and 4 years ago and get something new to run in a street class instead of dumping more money into it ...
I'm at ~25 1/4" front and ~25 5/8" rear FTG. That's with my 235/45R17 street tires.7" was what I was coming up with... but would be loose at full droop. No silly noises/popping driving around/driveway entraces/etc?
Can you remind us of your spring rate? (and ride height )
