I don't know this for sure because I have not run the setup but I am going to put this out there as a hypothetical. Lets say you are doing high-G high-speed braking. The rear tires have less grip because of the negative camber and the suspension is going toe-out on its own (more so if you have compliance bushings). It seems like the combination of negative camber and toe-out here could make the car progressively more twitchy as you drive the car into the apex.
I don't know your track experience, I apologize if I'm talking down to you.
If you are newish: you want to error on the side of an understeering setup. Yes, it feels bad in slow corners, but you don't want to be surprised in the fast corners. I suggest running a healthy amount of rear camber (meaning more negative). Not crashing is more important than lap times.
If you are comfortable on track, I'm saying it's probably safer to balance your handling by
incrementally increasing rear toe out. Don't go straight to .25". If you get yourself into a comfy place using toe, the breakaway will be slower than if you do it by decreasing camber. Snap oversteer is no good.
For autocross and street use, .25" rear toe out is no problem, send it.
In the words of Andy Hollis,
"So how do we make the car stop understeering? One way, is to decamber the rear, as you have been doing lately. But that is a fairly sudden breakaway, and actually doesn't make the car any faster (it just feels better than "riding out the push"). Here's another key point: Under steer is when the slip angle of the front tires is larger than the rear tires. One way to open up the effective slip angle of the rear tires (reducing understeer) is through toe-out in the rear. This "steers" the rear tire to a larger arc than it would otherwise be at."
