Street Touring Hatchback (STH) discussion/setup
JackRabbitSLIM
OHIO
MK7 GTI
No thanks. I turned stability control off for a reason :)
I think it's more accurate to say you turned TCS off because the OE system is poor enough that a human can be better. The COBB stuff pull ignition waaaay faster than the OE system. The Kuehl's multi-time national champion SMF car had the Hondata TCS, which works the same I'm pretty sure, and I remember him talking about how much of a game changer it was.
I'm not sure what everyone's tune situation is, it's possible this is active and they don't know it, especially if using an Accessport.
I have APR stage 1 high torque. I still don't know how much of a problem I have because I'm yet to drive on high grip in warm temperatures, but even on my last run in ~60 ambient on asphalt I cannot go full throttle without getting kicked off my line. Is that what everyone is dealing with?
I live in Florida, so I'm not sure what this cold tire phenomenon you speak of if, but same issue with heat cycled out tires. No issue with fresh rubber.
JackRabbitSLIM
OHIO
MK7 GTI
I can't find the thread right now but I'm almost positive that I found a post from Ed at EQT saying he has this active on almost all of his tunes...Maybe your signature is old but if you still have an EQT tune, I bet this is enabled.
Found it
https://golfmk7.com/forums/index.php?threads/eqt-e-tuning-q-a.361928/post-7272925
xXDavidCXx
AZ
2017 GTI SE DSG
To clarify, I realize that at some level, TC on a car with more power than the grip conditions allow may be faster with a good TC system, but I turned ECS fully off because the ECU would still pull power for stability reasons.
I’m not opposed to a tire-spin torque-limit only system though.
JackRabbitSLIM
OHIO
MK7 GTI
I'm pretty sure that's what this COBB system is, and so far I have that problem. Anyone else?
JackRabbitSLIM
OHIO
MK7 GTI
It's both fronts breaking free under throttle. Alignment is -3.6* and .125" toe out. I have VCDS, I do have the Torque limiter off. I did that before autocross so I guess I could play with that, kind of forgot about this. XDS is off.
This one:
Torque limiter off
ABS -> Adaptions -> Starting Vibration Control -> Disable (old setting: Strong)
Edit: after some more research, it seems like that mod could be my issue. hahaha, oops. I turned that off chasing an issue I have sometimes on the highway and forgot.
bfury5
CT
I have similar on-throttle massive push if I'm on the throttle too early in a sweeper. I chalked it up to no-lsd, and I'm learning how to carry more speed through the corner to compensate
I have everything possible turned off, I found that with certain things on if you accidentally induce tire spin push it will shut things down and cost more time than dealing with a small amount of slip and correcting.
Also for reference I'm on stock tune, so I can only imagine it's worse when tuned
JackRabbitSLIM
OHIO
MK7 GTI
Did you try all the torque limiter settings?
bfury5
CT
I didn't try all of them, once I found out they could be turned off I went that route. That's just personal preference though, as the only variable now is my right foot and not if/when and to what degree any sort of limiter intervenes. I probably made it more difficult for myself but I preferred the single pronged approach
jmblur
Massachusetts
2017 Golf R
Finally got everything buttoned up. Alignment tomorrow. R not GTI if that matters.
Assuming I'm at -2 camber front (hopefully!) I'm thinking -1.6-1.7 rear camber, zero toe front, slight (1/32") toe in rear to start, then maybe play games with rear toe later?
Mini7
Charlotte, NC
2017 GTi Sport PP
For auto-x or track? What tires are you running?
I know you were installing CSS swivels and if I recall correctly a fixed camber plate.
jmblur
Massachusetts
2017 Golf R
Autox/street use. May run some hpde as well but not til fall at least.
CSS knuckles, no camber plates. Golf R stock has roughly a degree of negative camber. Did some rudimentary measurements last night and looks like I'm roughly 1.9 deg neg camber now.
xXDavidCXx
AZ
2017 GTI SE DSG
I’d run same camber front to rear in your situation and then run 1/4 inch total rear toe out, instead of less rear camber.
