xXDavidCXx
- AZ
- 2017 GTI SE DSG
Just go right to 700-800 in/lb springs.Howdy,
So, put on the 034 rear bar (soft setting) and bumped the rear springs to 500 in-lb (Apparently the ST XTA kit is 400 front, 260 rear). Autox yesterday. For sure a step in the right direction. For the first time, really tossing the car into a corner would get the back moving. But not really enough. Still pretty bad understeer unless you really tried to drive like an idiot.
For the rear springs, 8" 2.5" ID coil overs put me right into the butter zone in the middle of the rear adjuster at my current ride heights. Which was handy, because I had some springs sitting on the shelf.
For the next event, I'll try going to the 550's I had sitting beside those, and bump the rear bar to the stiff setting. Going to add some helper springs as well. On the lift, the rear springs/top adjusters aren't _quite_ completely free of the OE spring centering bulge, but its darn close. I don't think they could ever get loose enough to actually come completely out of the seat in usage (when cornering, the rear bar would keep enough pressure on the inside rear I think), but helpers will mean I don't need to think about it when jacking the car, if I go stiffer yet, etc.
Mark
The motion ratio in the rear is almost 1/2 of the front, meaning a 50 in/lb increase is hardly noticible.
If you get helpers, also get a spring coupler so the two springs don’t slip around.
With an 8 inch spring, I would not bother, considering you will need another corner balance and alignment. It’s not worth the hassle.
