I attached a calculator for both of those pages ago. I don't have the measurements for the 034 rear bar, with some assumptions, the wheel rates would be around 1000F/900R (in roll, so including swaybars) and suspension frequencies of around 2.3F/2.4R.
I was going to say this before when you guys were talking about suspension frequencies, I'm wondering what you think that is telling you? The natural frequencies and those bump charts of the "rear catching up to the front" all assume some specific decay amount. Now, do you (the general "you") think you have your dampers set to the exact critical damping setting? I very much doubt it, and I don't know why it would matter to anyone. Yes we hit bumps during autocross, but is keeping those traces lined up worth more than tuning your dampers to give you handling you want?
Dave, you just dropped your front damping way down at the last event, and your performance was better, right? And you are at LAP, where the bumps are actually pretty bad in certain places. Did you think your ride frequency was unchanged? With the rear full stiff, you are certainly over-damped (more damping, less weight), meaning the oscillation dies without overshoot. The front by contrast is heavier and your damping is far less due to your setting, so you could be underdamped. Don't forget that the y-axis unit on the shock dyno's is a force unit, same as your spring. So when you change your damping you are changing everything about those decay graphs. My whole point in typing all this BS is that you really don't care about this, you just think you do.
