anotero
- Hither and thither
- Mk7 GTI
I wasn't able to find much useful info on what happens when this feature is deactivated. Are there any benefits to turning this off?
I read that before starting the thread.Not sure what you're asking here...is this something you found in VCDS to change? I wouldn't turn anything brake related off though.
Good info here so the question is...are you tracking your car?
https://drivetribe.com/p/performance-vcds-tweaks-Dky7b-PTQpqIwVFrasMoeA
Yep. Thanks.The benefits are increased potential for losing control of your car when you are driving extremely fast and slamming on the brakes. Is that something you are looking for?
I'll need to test it out. Thanks.Or it does the complete and total opposite. I had a really weird side to side shimmy under hard braking and had no clue what it was. It felt like a caliper on one side hung up followed by one on the other. It would happen regardless of brake temperature or pad/rotor/fluid condition. It also elongated stopping distances and present pedal feel similar to brake fade. I turned straight ahead brakes stabilization and hydraulic brake assist off now I can stop from any speed with ease and predictability.
I'm not quite sure in what scenario this system would help, but if you've ever felt a whole car shimmy under braking this is likely your cause!
