GoatAutomotive
- Georgetown, TX
- 2017 VW GTI SE, DSG
**new and exciting updates being added, including test results from an upcoming 5/10 track day…stay tuned!”
Feast your eyes, gents. I scored a very nice deal on a 28mm H&R front sway bar to compliment the 25.4mm rear bar I've had on the car for several years now.
And it only comes in "Delicious Blue"...
4/19/23 - FSB Install & Write-Up in Post #19
I'm also pulling the trigger on these (below) after many hours of research into the adjustable camber mount options for our cars, since installing LCAs w/additional camber, or employing GTI Clubsport knuckles, can be substantially more expensive to accomplish the same result:
4/19/23 - FSB Install & Write-Up on Post #18
For a fun baseline, see the pics at the bottom of this post showing Stormy on track 3/15 with the stock 24mm FSB and a beefy 1” rear APR bar.
Moog HD ELs all around and they are awesome.
If I didn’t f*** up a line/corner entry, the under steer was verrrry controllable, but body motion control needs work… Hence this discussion below.
Sway Bar Intro:
It's always surprising how the sway bar topic attracts as much misinformation and confusion as people asking "which spark plugs should I run on my tuned MQB?"
There are some very nice package deals available from top-name suspension companies where you can purchase the front and rear bars as a pair to save some coin, and have the most complete, balanced result.
The elephant in the room is the front SB install, which intimidates most, since it involves lowering the front cradle, and being mindful of some critical mechanical and electronic items up in there.
Gratefully, this platform doesn't have the motor mounts integrated into the subframe like most passenger cars do, so lowering and supporting the front cradle is quite easy if you have the basic tools required for brake and suspension work. The motor and trans stay in position by way of the OE fenders/body in the engine bay.
A smaller ~1.5 ton aluminum floor jack and a nice 2x4 to spread the load (that's what she said!) will go a long way, and allow you to safely lower the cradle in a controlled manner.
Some have said they only had to lower the front part of the cradle, with the rear bolts loosened a few turns, to gain the needed access for removing the stock FSB. I will report on this first hand in a week or so when I do this install in my shop. I did precisely this to install my Whiteline front LCAs back in early January, with excellent results.
To keep this post concise, I'll simply reference the FSB install procedure here, as a PDF, courtesy of the good folks at 034 Motorsports:
https://www.034motorsport.com/docs/...t-sway-bar-install-guide-diy-034-402-1009.pdf
*Note on the above: DO verify all torque specs with VW factory specs when consulting aftermarket install guides.
1) I recommend anyone on the fence about a front SB consult the above walk-through. It should put you at ease; eliminating your unknowns and apprehension. It also shows you what a qualified shop will be doing if you need to pay a professional.
2) Front subframe hardware and sway bar hardware, from the factory, is 1-time use, TTY fasteners.
3) Some of the front sway bars offered will include new brackets and hardware for the bar itself. Look closely at what's included in the FSB you select, as new TTY bolts for the FSB might not be needed. Only the front cradle bolts.
4) You can and should purchase a new set together from one of our vendors, or even from your local VW dealer if you're in a pinch.
5) And yes, after lowering or removing your front cradle, you absolutely should have the alignment touched up or verified by a qualified shop with a good Hunter machine.
6) If you don't mind the steep $300 cost, you can spring for a Tyrol Sport Deadset kit at this time, which will properly center and locate your front cradle, every time.
https://www.tyrolsport.com/suspensi...igid-subframe-kit-for-mk7/mqb/a3/s3/rs3/ttrs/
Part of the expense (and appeal) of the Deadset kit is the inclusion of the drastically superior, multi-use ARP hardware to mount the subframe, instead of the factory 1-time use bolts. I hate TTY bolts. A lot. But I understand why OEs employ them.
..."My chassis, my choice!"
7) As an alternative, 034 Motorsports offers a simpler, more affordable kit that accomplishes a similar centering/locating effect for the front cradle, but with the use of factory style TTY bolts. If they used a higher quality fastener like the Tyrol Sport DSK, this would be an outstanding buy @ ~$142.
See below:
https://www.fcpeuro.com/products/vw...sfYvNQEGtik_Atu6x-Q3PgYxoCWW4QAvD_BwE#fitment
Purchasing a centering kit like the ones detailed in lines 6 & 7 will remove the guesswork and struggling from properly centering your cradle after it's been dropped.
ALL THAT OUT OF THE WAY, let's jump to why I'm doing an FSB now, instead of the stiffer coilovers I desperately want:
1) I'm poor AF this year. Everything has become unaffordable or unreasonable, and I'm a single income, single parent with a house.
2) My normal mod money, a shamefully small amount, is being used on track time for 3 events March-May.
Seat time is gold. Veterans who auto-x or do HPDEs will verify this if you ask.
...Even the fastest, most heavily modified car needs a driver who knows WTF they're doing, in order to extract the performance potential out of it.
3) I'm very happy with the street manners, ride quality, and isolation of my current setup. It's better than I'd hoped, truly.
...The Sachs dampers have calmed down a LOT in recent months, without ever lacking the ability to control the spring movements over bumps, dips, etc.
...There is no crashing or bouncing behavior to speak of, which to me speaks volumes about the design and ride height of the OE Sport springs.
4) With MacPherson strut suspension setups, stiffer sway bars help preserve your static camber in dynamic turning situations:
...Less body roll means less "camber-loss" in cornering situations. This is VERY important if you're looking to exact the best lap times or strongest corner speeds from your car.
5) I worry I might have buyer's remorse moving to coilovers with solid front strut mounts, due to any increased harshness or noise. This is a gamble I can't afford at the moment.
6) Even with an RSB, I still feel the car has more loft on turn-in and lane changes than it should, particularly from the front half of the car.
7) Adding to #2, these same HPDEs have me craving more body control and faster cornering speeds to reduce my lap times.
Inertia Addicts
The cars and drivers in my HPDE group were VERY fast this last time on 3/15. It was obvious they'd been doing this for some time.
I'm hoping I can make a better showing on the 4/12 Track Night event with the addition of a FSB and some camber mounts, now that I've dusted off the cobwebs from my old track days that ended ~2016.
For how my car behaved on track this month, these minor upgrades should yield a substantial improvement.
And if I'm wrong, no one can say I didn't try!
That's the full explanation.
For context and comparison, you can look over Stormy's current setup below, and how the car is used:
2017 VW GTI SE, DSG, 42k miles
Suspension
-APR 1" RSB
-H&R OE Sport springs for ~20-25mm drop (and no more!)
-Stock Sachs dampers (they're still working well, they're paid for, and I am on a budget tighter than the e-string on Lindsay Sterling's violin)
-Stock strut mounts & bearings (for now) - these were verified in January to be in good working condition as-is
-Moog HD greaseable end-links all around (to eliminate deflection inherent to the stockers when pushed hard)
-Neuspeed 18x8.5" RSE10s wrapped in 245/40R18 Michelin PS4S (weight reduction + GRIP!)
"Stop Me Harder, Baby"
-Powerstop Z23 kevlar-ceramic front pads, clamping Raybestos coated, high-carbon rotors
-RS3 brake ducts going on next week
-Stock "coal-miner's daughter" TRW organic pads out back from "zee jer-menz" (VW OE pads) biting down on the OE rotors
The power mods to the engine are largely irrelevant here, so I won't go into that. We can safely call this a "Stage 2 car" making solid power on 93-octane w/the stock IS20.
Usage
1) The car is driven on the street 80% of the time, with some very fast backroad and canyon driving once a month with my car club.
2) We also go out to our local snakey-canyon dragon road (LCR) twice a month on Sundays; to socialize, and to run our cars along some wicked hairpins and corners.
A surprising amount of 6-figure cars routinely go out there to play and work on their driving.
Most of the folks in my car club are packing Porsches and BMWs with better traction and rotation, plus a Mk6 Golf R on coilovers with the stock K04 on a "kill map," and a #drivermod banging the gears.
There's also a brand new 480hp Ford Mustang Mach 1 on factory Michelin PS Cup 2s wider than a powerlifter's back.
In short, there is no absence of talent or power in this group.
3) I am getting back into HPDEs and will likely do 6 a year, limited only by the Texas heat (May-September), and my budget. aka "Po' A.F."
Preamble complete, the next section will delve into...
-suspension dynamics
-the sliding scale of stiffer springs versus stiffer sway bars to improve handling.
-It will clarify how a larger set of sway bars can impact your car.
And it's gonna go in depth, since this is a heavily discussed subject, yet the threads are filled with 80% conjecture and only 20% actual FSB owners and track hounds who know what they're talking about.
Stand by for the second post...
