davegsm82
- Blyth, Northumberland - England
- MK7 Golf and T3 Tdi
Hi Dave, sorry about the (very) late reply!
thanks for mentioning this, how hard would this be for someone with virtually no experience or skill set to do (me) . I really do want this to work but just keep putting it off. If itās possible would I just be able to get this wiring sorted, how do I check if the radar itself is good? - I may have a stab at having a look at this canbus wiring but how would I check if itās working or needs repairing. I also have the domed radar too. Lastly how much would this cost for me to either do myself or pay someone to do??
Once again thanks for your post
Hi Isacheema,
Ok. So I've been on a bit of a journey with this over the last couple of weeks.
Short story of it is, the radar itself was knackered. Long story is, I'd been through all the wiring, checked the power supply to it, checked the grounds etc, I made myself a canbus interface and found that the radar wasn't communicating at all sometimes. You'd turn on the ignition and nothing, which is when you get the Stop-Start error.
But. I'm an electronics engineer so once I'd exhausted all other options, I ripped the Radar out and dug into it, to see if I could repair it.
In my case, I've been able to actually repair the radar and have been considering the possibility of offering a postal repair service for them, because the alternative is extremely expensive. Working domed front radars are few and far between on the used market, Ā£200-300 and after that you have to have component protection removed (Ā£100-200) and potentially have ADIS calibration performed which seems to be quite variable but VW/Audi charge something like Ā£500.
The problem with these radars is water ingress, the rubber seal around the back of the units fails because of aluminium corrosion, then they fill up with water and either the connector on the bottom falls apart or you get lucky and one of the components on the board blows, saving the rest of the unit. I've 'autopsied' 3 units in total and they all feature the same type of water ingress. I dare say that EVERY one of these radars will fail this way eventually.
You can see a picture of the inside of my radar on this page; https://golfmk7.com/forums/index.ph...-when-swapping-parts-info.386155/post-7674014
The repair process is very labour intensive unfortunately, it has to be stripped, every one of the corroded screws holding the back cover on will snap, The electronics then have to be extracted and repaired if possible. If it's viable then the snapped screw studs have to be extracted by either welding on nuts or drilling them out if that fails. The case has to then be shot-blasted and the whole thing reassbled with a new rubber seal etc, all of this takes hours and hours.
Upshot is, if you repair your old radar then you should be able to just clip it back into place and conserve your original calibration. Only downside is you can't guarantee your Radar will be repairable :-/
