Stop Start error & ACC not working
isacheema
West Yorkshire
GOLF GT 2.0 DSG MK7
Hi All
I’ve posted about this issue once before and I thought I’d ask again, but this time provide all of the codes available. At first it didn’t bother me that the ACC didn’t work, but I’m doing more motorway journeys that would really be easier if the ACC worked. I have got limited diagnostics attached below, so would anyone be able to help me understand it? As far as I know there is no communication with the front radar (dome shaped) which is causing the stop start and ACC to not work. Is there any way for me to disconnect and reconnect the radar and if so can someone be kind enough to show me how!! I’ve had enough of seeing the stop start error everytime I turn the car so just want the problem sorted. Side note: I’ve had the battery replaced but this has not rectified the issue, so any help would be greatly appreciated. There’s also a code for control module incorrectly coded, but my parking sensors work fine?
here is the diagnostic
CAN network gateway
Part #: 5Q0907530F
Component: GW MQB High
Software version: 1109
ASAM/ODX identifier: EV_GatewLear
Coding: 030100040B087300EF00045C1C0F00010001000000000000000000000000 (hex)
Fault codes:
131671 Manufacturer-specific code
Central electronics
Part #: 5Q0937084N
Component: BCM MQBAB M
Software version: 0106
ASAM/ODX identifier: EV_BCMCONTI
Coding: 03101842C2C1027B0FA44080B10403A8100A000000000000000000000000 (hex)
[No fault codes]
Steering wheel
Part #: 5Q0953507AG
Component: Lenks. Modul
Software version: 0070
ASAM/ODX identifier: EV_SMLSKLOMQB
Coding: 0D00 (hex)
[No fault codes]
Parking/steering assist
Part #: 5Q0919298A
Component: PARKHILFE PLA
Software version: 0029
ASAM/ODX identifier: EV_EPHVA2CAU3700000
Coding: 0131061051 (hex)
[No fault codes]
Airbags
Part #: 5Q0959655M
Component: AirbagVW20
Software version: 0361
ASAM/ODX identifier: EV_AirbaVW20SMEVW37X
Coding: 98CCC000000000005C0000CF00C800000065 (hex)
[No fault codes]
Instrument cluster
Part #: 5G0920970A
Component: KOMBI
Software version: 0580
ASAM/ODX identifier: EV_DashBoardVDDMQBAB
Coding: 2BA5010827902E0001887A01040000 (hex)
Fault codes:
16777028 Manufacturer-specific code
16776960 Manufacturer-specific code
16776961 Manufacturer-specific code
ABS
Part #: 5Q0907379AD
Component: ESC
Software version: 0537
ASAM/ODX identifier: EV_Brake1UDSContiMK100IPB
Coding: 01FA8AA120260A75037A060601C72980510450C0608094F3F86A502AC1 (hex)
Fault codes:
08192 Manufacturer-specific code
08196 Manufacturer-specific code
Power steering
Part #: 5Q0909144L
Component: EPS_MQB_ZFLS
Software version: 1021
ASAM/ODX identifier: EV_SteerAssisMQB
Coding: 83 (hex)
[No fault codes]
Heater & air conditioning
Part #: 5G0907426J
Component: AC Manuell
Software version: 0503
ASAM/ODX identifier: EV_ACManueBHBVW37X
Coding: 00120104202100001000000000000000 (hex)
[No fault codes]
Front passenger's door
Part #: 5Q4959592
Component: TSG BFS
Software version: 0006
ASAM/ODX identifier: EV_DCUPasseSideEWMAXCONT
Coding: 001B0020DE01028000801000 (hex)
[No fault codes]
Driver's door
Part #: 5Q4959593
Component: TSG FS
ASAM/ODX identifier: EV_DCUDriveSideEWMAXCONT
Coding: 001B0220D001028000001000 (hex)
[No fault codes]
Transmission
Part #: 0D9300040A
Component: DQ250-6F MQB
Software version: 3613
ASAM/ODX identifier: EV_TCMDQ250021
Coding: 0014 (hex)
[No fault codes]
Engine
Part #: 04L906021DT
Component: R4 2,0L EDC
Software version: 4943
ASAM/ODX identifier: EV_ECM20TDI01104L906021DT
Coding: 011D0032036505082000 (hex)
Fault codes:
04709 Manufacturer-specific code
Infotainment system
Part #: 5G0035858
Component: MU-S-ND-ER
Software version: 0170
ASAM/ODX identifier: EV_MUStd4CPASE
Coding: 02730001FF0000002111120100A800001F0100860100010047 (hex)
Fault codes:
01543 Control module incorrectly coded
07173 Manufacturer-specific code
07195 Manufacturer-specific code
Obtained with Carista 543099 for iOS.
IWMTom
Hi All
CAN network gateway
Part #: 5Q0907530F
Fault codes:
Central electronics
Part #: 5Q0937084N
[No fault codes]
Steering wheel
Part #: 5Q0953507AG
Coding: 0D00 (hex)
[No fault codes]
Part #: 5Q0919298A
[No fault codes]
Airbags
Part #: 5Q0959655M
[No fault codes]
Instrument cluster
Part #: 5G0920970A
Component: KOMBI
Fault codes:
ABS
Part #: 5Q0907379AD
Component: ESC
Fault codes:
Power steering
Part #: 5Q0909144L
Coding: 83 (hex)
[No fault codes]
Part #: 5G0907426J
[No fault codes]
Part #: 5Q4959592
Component: TSG BFS
[No fault codes]
Driver's door
Part #: 5Q4959593
Component: TSG FS
[No fault codes]
Transmission
Part #: 0D9300040A
Coding: 0014 (hex)
[No fault codes]
Engine
Part #: 04L906021DT
Fault codes:
Infotainment system
Part #: 5G0035858
Fault codes:
Yeah I don't see an ACC module there, so looks like it can't be reached on the CANBUS. That suggests you either have a wiring issue, or the radar module is defective.
isacheema
West Yorkshire
GOLF GT 2.0 DSG MK7
Hmm that’s not good 😬 could it just be as simple as unplugging it and plugging it back in and if so how do it do that? I can see a plug coming from the bottom of the radar, shall I try that? If I do need a new radar, how much would this cost (the part, fitting and would it need calibration?) is there a guide on how to remove the plug on the radar, because I’ve looked and there isn’t much space
thanks
IWMTom
thanks
I'm afraid not.
First thing to try would be to check continuity on all of the wires leading up to the radar. From memory, there should only be four. Two CANBUS, one power, and one ground.
If all the wires are fine, I'd be replacing the radar. Yes, it should require calibration.
isacheema
West Yorkshire
GOLF GT 2.0 DSG MK7
I'm afraid not.
It’s chucking buckets right now so I’ll check when it’s done. Last time I checked they seemed to be there but I’ll have another look
I’m guessing I’ll just have to buy another, would any old one do off eBay? And how much would calibration cost?
IWMTom
You're not looking for whether the wires are still there, you're checking continuity! Power and ground are simple, but for the CANBUS wires there's a connection block on the passenger side behind the trim where you can check the first leg of the run.
I'm not completely familiar with the dome radar, but my understanding is that it's much easier to swap as there's no component protection. In other words, yes, a matching used part from eBay would be fine.
Calibration can vary depending where you go. Cheapest I've seen is £130 at VW Retrofit in Redditch. Some VW dealers will charge in excess of £500 as they insist on a full wheel alignment first.
isacheema
West Yorkshire
GOLF GT 2.0 DSG MK7
As you can see I’m not very mechanically minded! I still have no idea what checking for continuity means.
and yes mine is the dome shaped radar and I’ve found one on eBay here, is it any good? And that’s good to hear, hopefully I find a working one as I can’t seem to find the dome shaped one anywhere
I’ll need to find a calibration area near me before I purchase one, hopefully I can find one under £150
IWMTom
You'll need to check your current part number first. It'll be on the back of the radar.
