Stock or Tuned - Post Your Dyno Results!
MacG1
Today’s Dyno...FBO, 77 degrees, 33% humidity, Phoenix AZ...GIAC Stage 2+, 93 Octane IMG_2689.JPG
Jovian
Sunnyvale, CA
2016 VW GTI
Stock-ish GTI.
Revo TIP
RS7 plugs
K&N filter with snowguard removed
91oct
Tuned by ED @ EQT /w Cobb
Pink is ED's tune
Blue is my early e-tune by another tuner
Green is stock
uberpolka
Portland
2017 GTI
virtual dyno is all I've got for now
This is with crappy 92 octane fueling.
bluekid99
Pennsylvania
Made 370whp and 365wtq on my setup on a dynojet in about 45 degree weather last year. I havent changed any mods from my sig
NeedSleep
2016 Golf R DSG
Got my car on the dyno today.
Current setup is IE intercooler, BFI Stage 1 mounts, AFE dry filter in the stock air box, and JB4. I'm running E30 at best (haven't tested actual ethanol content), mixing E85 and 91 octane.
My JB4 map 6 settings are as follows:
1500 - 2.0
2000 - 3.0
2500 - 4.0
3000 - 4.5
3500 - 5.0
4000 - 5.0
4500 - 6.0
5000 - 7.0
5500 - 7.0
6000 - 7.0
6500 - 6.5
7000 - 6.0
All runs were in 4th gear, so the 124mph speed limiter was hit. The first 2 runs were on map 6, and the last run was on map 0 (stock). I did it in this order because I recall reading somewhere that going from map 0 to others takes time to adapt, while going from other maps to any other map (including 0) is instantaneous.
The first peaked at 272hp/336ft-lb. The second peaked at 273hp/339ft-lb.
The map 0 run peaked at 221hp/286ft-lb.
Unfortunately, I didn't log when they were doing the pulls. When the car was idling as I switched maps, though, the JB4 was reading 129°F IAT. Ambient temp at the time was 62°F at 70% humidity. 20190301_172852.jpeg
Sent from my SM-G930T using Tapatalk
GroceryGTIer
Tri-state
1500 - 2.0
2000 - 3.0
2500 - 4.0
3000 - 4.5
3500 - 5.0
4000 - 5.0
4500 - 6.0
5000 - 7.0
5500 - 7.0
6000 - 7.0
6500 - 6.5
7000 - 6.0
Unfortunately, I didn't log when they were doing the pulls. When the car was idling as I switched maps, though, the JB4 was reading 129°F IAT. Ambient temp at the time was 62°F at 70% humidity. View attachment 25686
Why didn’t they do a 3rd gear pull?
yirayira
Chicago, IL
2015 GTI SE
What was the temp at the dyno?
