They use the same reservoir but not technically the same fluid because the circuits are separate. You can replace the clutch bleeder and only need to bleed the clutch. You can also replace the brake lines and only need to bleed the brakes. Same reservoir and same fluid being added but they don't communicate with one another.How's that possible? That would imply that they use the same fluid which they don't
