He didn't say anything about the number of misfires did he?
He said the code is for misfires.
Well I certainly didn't read it very well.He said the code is for misfires.
So no one thinks it could be carbon buildup or fuel injector related? I’ll try to go get some logs now
Not sure how to find out the number of misfires. I was able to catch a log with EPC light activation but I’ll have to sift through like 30 logs that I just took. Pulled over and flashed to stock, did a couple pulls on Map 0 I was showing a highest knock average of -2.62. I wasn’t able to get the EPC light to come on with Simulated stock map but I also was tired and didn’t do as many pulls.He didn't say anything about the number of misfires did he?
Ran to hazard fraught and got a compression tester. All 4 cylinders were 180+\- 10. It is harbor freight but even if it reads high all 4 are reading about the same. I’m attempting to post a pic of the spark plugs with ~500ish miles and a pic of the compression test.Time to do a compression test, cross your fingers, and hope for the best. Although if you've eliminated plugs and coils as the problem, the outlook isn't looking good.
Obviously the problem isn't compression or plugs. Those plugs look good.Ran to hazard fraught and got a compression tester. All 4 cylinders were 180+\- 10. It is harbor freight but even if it reads high all 4 are reading about the same. I’m attempting to post a pic of the spark plugs with ~500ish miles and a pic of the compression test.
