Hey all 2016 Mk7 GTI with 72,000 miles. I went EQT stage 1 a couple thousand miles ago and am getting a misfire code that will pop up occasionally during a long WOT pull. EPC light will come on and cylinder 2 will be deactivated. Turning the car off and on clears the EPC light.
So far I’ve:
1. Replaced and correctly gapped spark plugs
2. Swapped coil packs around assuming cylinder 2 is the second from the left when looking from the front of the vehicle
3. Reflashed stage 1 just in case it was tune related
I’m still getting a misfire and trying to figure out what my next steps are. It looks like injectors would be the most likely next culprit and I was planning on doing a carbon cleaning while I have the intake manifold off to do injectors. I have owned the vehicle since new and have never done a carbon cleaning. Is there anything I can test for before I start replacing things?
So far I’ve:
