Pickleahoy
- Deland, FL
- 2016 Golf R
Install should be reverse of removal, if you used a 2x4 to remove the stock shock, you would need the wood piece to compress it the same way.
Might try that but I was going with the shopdap axle disconnect method after my initial poor start with the 2x4 method.
All good reasons to not use this method.I took another look at the 2x4 method. Here's my problem - the strut and 2x4 are at a bit of an angle so when I jack them up they push the jack outward - very annoying, but maybe this is why two people are needed. I'd like to see the 2x4 method used to reseat the strut into the knuckle - strikes me as more difficult than removal since you need control.
The issue I was having with the shopdap axle removal method is that the knuckle studs seemed to be in conflict with the lower control arm. I'll try again tomorrow. Otherwise I might look at removing the brake which should remove some weight and free me from worrying about the brake lines.
1. Loosen axle bolts with wheels on the ground
2. lift both sides of the front
3. Remove wheels
4. Disconnect the sway bar from the strut, both sides if removing both struts
5. Remove the entire caliper via the two bolts, both bolts are reusable
6. Remove the rotor (for ease of access and lightens the load when re-installing struts)
7. Remove the lower strut pinch bolt and toss the bolt and nut in the trash
8. Remove the 3 lower ball joint nuts and toss in the nuts in the trash
9. Push the lower arm down and pull the ball joint out of the arm, the strut assembly should move freely.
10. Insert strut separator
11. Use a block of wood and a hammer, if needed, on the knuckle rim to force the knuckle down the strut shaft. Work the strut separator in different positions as needed to create the required space.
Most VW hardware is one-time use. It's called torque-to-yield.Thanks for this. Before removing any nut or bolt from the car I want to (assuming I have the tools)
a) see if I need to replace it
b) know what the torque specs are
I do not have these on hand. Not sure how strong the recommendation is to replace but I don't want to open that can of worms...
Sounds weird maybe but 2x4 is far from the ideal size for this method, it's so annoying it actually goes by this name as you're probably going to have issues if you use that size. Yes maybe you can pull it off with an actual 2x4 but it's un-necessarily bulky, it limits how close and how parallel the wood can come to the strut (which is paramount for the success of the method) and creates more risk.
I went with a ~2x2 (actually 45x45mm) and was able to place the wood perfectly parallel to the strut. In fact the wood was lifting the strut up via the connected bolt, not by physically pushing on the spring seat which is i think the original concept but like this i had absolutely no issues of the jack tending to slip. Drilling the hole on the wood to be a snug fit (12mm max) also helps avoiding too much play between strut and wood.
And you are right about the lack of documentation for re-installation, that's where I lost a LOT of time till i figured out my buddy needed to operate the jack in very slow increments, and me wiggling the brake disc to get small bits of drop every time. On the second corner(passenger side) it went much quicker. So sorry I didn't get a video as i realize it would have helped others like me but at the time we were already 5hr out fighting it, it was getting dark and i was too pissed to think about making movies...
PS. Your issue in the previous page of the strut being lower than the knuckle to begin with, is resolved by compressing the assembly slightly by jacking up the 2x2 (i won't refer to it as 2x4 any more, lol), but you must have figured that out already
