Spring & Shock/Damper Installation Reference Guide
NopeR
18 Golf R
The passenger side front I find to be the hardest just because of its orientation with the knuckle and the FSB endlink.
With that said, the 2x4 method is by far the easiest way to get them out.
GTIfan99
Getting them back in with the 2 x 4 method is super sketchy though unless you're going really low. My buddy that helped me almost took a 2 x 4 to the hand when we overshot the hub and 2 x 4 slipped off.
I'm thinking ratchet straps on the springs would be safer.
Mother
Orlando, FL
Are you not using the modified 2x4 method with a hole drilled for the endlink bolt?
It doesn't have to compress it that far. Just the last little bit since the hub drops so far.
GTIfan99
No, just wedged it under there. Your way sounds safer. Lol
snobrdrdan
former GTI owner
See...I always had the easier time on the passenger side. The strut doesn't wanna rotate.
On the driver's side, it DOES want to turn/slip rotate off the 2x4.
Attaching the bolt to the 2x4 does help prevent that problem though.
NopeR
18 Golf R
Man, I never thought of that lol. I've taken the suspension on/off my old gti around 7 times without securing the 2x4 like that. I'll definitely drill and secure it when I do the R this spring.
shortyb
Upstate SC
Felon Taxi,Dad Wagon
I, personally, always use new ones.
No point in pairing old parts with new ones, that'll be your weak link. It's a giant rubber bushing, essentially, btw.
But if you wanna be cheap...I'd keep it under the 20k-30k mile range. Unless you want to tear down the suspension again to replace them in the future.
Do it one time and do it right, IMO
Smart advice.
With front mount bearings, a lot depends on what duty cycles they undergo. As said, lots of rough road use will cause them to deteriorate more quickly. Also they sometimes take a "set" and will make noise if not re-oriented exactly as removed. At a minimum, check for smooth operation of the bearings. Or just don't take chances and replace them like Dan said.
shortyb
Upstate SC
Great job! Question on the torque specs, not questioning the validity, but what is the source? Some are quite different than the ones I’ve collected.
Also, what strut spreader do you have there? I’ve only ever seen the bit style. Fancy. ?
The torque specs I offered up came directly from the repair info supplied by VW. While I don't question the source validity given by zcspec either, I do question the differences from what is in the repair info database for the MK 7/7.5. There is no additional rotation mentioned which has been stressed everywhere I've seen referencing the proper fastening/torquing of certain suspension components. See my post #142 for some insight.
Also, in the first post the tightening spec for the front pinch bolt is incorrect. I believe it should be 70Nm (52 lb/ft) + 180° additional turn instead of 90°.
GTIfan99
Everything is 2 ugga duggas.
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
Keep in mind that info is a few years old now. I think I got it off of the DAP video. That said, just getting to 90 takes a fair amount of muscle, even using a 1/2” breaker bar. I’d honestly be worried about snapping the bolt if I went to 180. ..but that’s what it says in the repair manual?
shortyb
Upstate SC
Yep. And I know what you mean about getting it that tight. Almost have an aneurysm everytime I do an install. Never snapped any bolts though, they are quite beefy.
