Man, that spreader chewed up that aluminum.
Yeah the metal nerd spreader bit did the exact same to mine. Not looking forward to going back in to install B8s soon.
I am close to installing my Koni Yellows, probably next weekend. Order one of those "new" tools on Amazon to see how it works. I also have one of those cam style spreaders but after hearing all the issues with koni being slightly thicker decided to get the spreading tool .
I’d just get new mounts and bearings.Been reading this entire thread for over an hour and feeling confident. I plan to install KW V2's on my 2019 (18k miles) here in the upcoming weeks (Spring). I've read suggestions about replacing upper strut bearing (5Q0-412-249-F) and that's fine. With the KW's, suggestions on how to install the upper strut mount? Remove from stock strut and transfer over to the KW?
The part numbers are in the first post of this thread. I ran the 034s for a bit... They added some harshness, as expected being aluminum, but also some noise when turning it really low speeds.Thanks everyone. What is the part # for the strut mounts? Or should I go 034 full set with bearings?
Minimal difference, but yes follow the KW instructions for the KW strutJust purchased the following from FCP:
(2) 5QM412249
(2) 5Q0412331E
According to the instructions KW provides for install, the top nut on the strut is 50Nm (37 ft-lb). Per page #1, stock strut indicates 60Nm. Assuming I need to follow KW torque specs instead?
Hi all,
Sorry to resurrect this old threat but been reading a lot.
I had a set of Bilstein b16 Damptronic coilovers fitted to my GTI and ever since the install the rears have been clunking at low speeds on all types of road surfaces.
I don’t think my mechanic replaced any bolts but the strut mounts were replaced.
Should I just go ahead and order the “everything” list from the first post and see what happens?
So how did this tool work out for you? I’m about to install some special actives on the front in a week or two and am sort of dreading it now after reading the last few pages. I already ordered this tool, just curious for feedback on it.I am close to installing my Koni Yellows, probably next weekend. Order one of those "new" tools on Amazon to see how it works. I also have one of those cam style spreaders but after hearing all the issues with koni being slightly thicker decided to get the spreading tool .
