That's not the VW way. When you get a chance, replace the hardware.i didn't replace anything, just reused the same hardware. i watched a couple videos and they just reused the same hardward, didn't mention anything about replacing them.
noWould you say it's feasible to remove the rear springs by getting the car on a lift and using spring compressors directly on the springs? it seems like there is enough space to tighten the compressors but I wonder why I haven't seen this being discussed at all as an option...
Part number: 8J0512149I just finished installing the APR suspension package on a friend’s GLI. I’ve pretty much maxed out the rear height adjustment, and it’s still lower than he would like. I remember seeing a thicker rubber spring pad somewhere. Can anybody point me to it?
Thanks!
Just a question, since I'm mostly familiar with Mk3s and Mk4s, this is my first new VW.
Why not just use a spring compressor to compress the spring, then use the spread tool to open the knuckle? Seems like it would be a lot safer and easier than the 2x4 method, not that I am above the 2x4 method. Is there not enough room in the wheel well or something?
Looking at installing lowering springs and shocks once it warms up, just trying to get my research out of the way. I promised myself I'd find a good shop to do all the work on the new car, but I can't help it.
1. Loosen axle bolts with wheels on the ground
2. lift both sides of the front
3. Remove wheels
4. Disconnect the sway bar from the strut, both sides if removing both struts
5. Remove the entire caliper via the two bolts, both bolts are reusable
6. Remove the rotor (for ease of access and lightens the load when re-installing struts)
7. Remove the lower strut pinch bolt and toss the bolt and nut in the trash
8. Remove the 3 lower ball joint nuts and toss in the nuts in the trash
9. Push the lower arm down and pull the ball joint out of the arm, the strut assembly should move freely.
10. Insert strut separator
11. Use a block of wood and a hammer, if needed, on the knuckle rim to force the knuckle down the strut shaft. Work the strut separator in different positions as needed to create the required space.
I've quoted my two posts on this install, I don't like the 2x4 method.Loosen axle nut with wheel on the ground, then take out the nut after taking the weight off the wheel.
1. Nut loose, then off
2. Remove caliper
3. Remove rotor
4. Remove lower ball joint nutsx3
After the job is done, the last step is to torque the axle nut with the brakes applied, no weight on the wheel, to 200nm/150ft/lbs.
Then with the wheel on the hub and weight on the wheel, turn the axle nut 180deg.
