Ikbrown
- Fair Oaks, CA
- 2019 Alltrack
Hey all, wanted to report back on the issue that I had posted about right after I installed Bilstein B8s with Neuspeed Sport springs on my Alltrack.
1. Steering wheel was aggressively self-centering, even if stopped with the wheel turned it would return to center - much more than normal. This was resolved with an alignment - it was behaving so poorly I thought it must be something more than just the alignment being off but I guess that's what happens when you lower your car 2.25" in front, 3" in rear. ha. Looking at the alignment printout the only numbers that were signficantly off was the toe, both right/left and total toe. Positive caster increased from the stock range but they were not able to adjust that at all - just resolved camber and toe.
2. Multiple warnings/lights (ABS Stabilization, Front Assist not available, TPMS, Error: Airbag). This was due to damage to the wheel speed sensor on the driver front side. When removing the strut assembly with the 2x4 method the wire got pulled tight and the connection was slightly bent/damaged in the process. The shop was able to repair the connection and the christmas tree lights are no more.
A couple notes on the front install for others:
- As stated before, get the right tools before attempting. Having the knuckle spreader made removal and installation of front struts easier - couldn't imagine attempting without it.
- Removal of the front struts was slow going with the 2x4 method until we used a strap placed under the jack and over the knuckle assembly to keep it from lifting up with the strut as we jacked up the strut. Brilliant recommendation by whoever it was who originally posted that idea. The passenger side was a breeze using that method from the get-go compared to the driver side where we remembered that halfway through.
- 80% of our difficulty in reinstalling the new strut assemblies in the front was due to misalignment of the strut to the knuckle. Once those two got lined up it was fairly easy to lower the strut in w/o resistance.
- Don't be a dumby like me, and just remove the wheel speed sensor wire from both the knuckle clip and the wheel well clip on the engine bay side to give you more room to not fuck things up. ha.
