Spring & Shock/Damper Installation Reference Guide
RopeJumper13
Falls Church, VA
17 GTI Sport
What would be the definition of "high mileage" in terms of whether to replace the strut mount or not?
The strut mount really isn't a moving part so I would estimate 60k+. It would really depends on how old and what kind of action they have been through. If you live in an area full of potholes or rough roads, etc... Another consideration is how often you plan on removing the struts.
snobrdrdan
former GTI owner
I, personally, always use new ones.
No point in pairing old parts with new ones, that'll be your weak link. It's a giant rubber bushing, essentially, btw.
But if you wanna be cheap...I'd keep it under the 20k-30k mile range. Unless you want to tear down the suspension again to replace them in the future.
Do it one time and do it right, IMO
JD-1
Do you know the part number for rear shock mount bolts?
zcspec
Orange County
MQB S3
Hey guys, I just wrapped up another DIY, specifically for spring/coilover install that can suppliment this thread. Let me know if you want me to post the video link.
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
Go for it. Updating the first post may be a no-go for me though. Last time I tried to edit it I got an error about it needing to be under 10K char.
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
Feel free to use this an another resource to install springs/coils on your MQB car!
Spring/Coilover Install DIY Video
Great job! Question on the torque specs, not questioning the validity, but what is the source? Some are quite different than the ones I’ve collected.
Also, what strut spreader do you have there? I’ve only ever seen the bit style. Fancy. ?
zcspec
Orange County
MQB S3
Hammersticks, I sourced the torque specs from 034 and ECS guides. As far as the "fancy" spreader, it's a "FIRSTINFO Universal Multi Functional Steering Knuckle Spreading Tool" that I purchased from Amazon. I also have the bit style, but after seeing what it can do to the aluminum knuckle, I waned to try something different.
VL3X
Delaware
2017 GTI SE
^^ Damn, that thing looks way more secure than the Metal Nerd bit I used. The bit can pop out of place and can grind away if not aligned 100% perfectly. If doing this job more than once, I'd recommend getting that tool zcspec has!
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
Updated the initial post with both of these. Thanks again! I also ordered the spreader. The metal nerd bit absolutely gets the job done, but I like the design of the firstinfo tool and will put it to use soon enough.
Nice guide, thank you.
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
I tried using the FirstInfo tool yesterday. In my experience, it didn't loosen the strut enough, at least using the 2x4 method. I tried for ~15 minutes but the strut simply wasn't budging. I then went back to the "tried and true" MetalNerd bit, and voila, it immediately dropped .5" with a gentle push down. The bit style also provides the flexibility of moving the bit up/down within the knuckle to account for the tab. The firstinfo tool has obviously worked for others, but so far, I personally prefer the MetalNerd bit for its flexibility, effectiveness, and cost.
growlyboi
WA
Mk7R
Just want to say thanks for this thread. I'm a shade tree mechanic, and with this info and a 2x4 was able to get my springs installed with relatively no fuss.
