I can't clear the code. Clearing it brings back the code right away.
I know right... Clearly their tune DID something as the problem appeared after their tune.I would select Bit 1, then see what the options are before just changing your 0410 to 0400. Lots of Mk7s came with 0410.
Edit: Posted while I was typing... and made my point, haha.
Edit 2: @VW'15GTI I see you're using OBDEleven which may not have the same long coding helper as VCDS. The Byte value is the Hex equivalent of the bits, so always look at the bits. If OBDeleven doesn't show bit descriptions then you're kind of shooting from the hip.
We're also past this point now but I'm not sure about the EQT's statement that cruise control cannot be controlled by the tune. That's not to say that EQT does anything with the cruise control for their tune, but cruise control is an ECU function, our cars being drive by wire and all. If the only thing that changed in your car is the ECU tune and you now have the different CC button behavior then it's clear the ECU tune is the cause.
