Hi All,
This may be more appropriate for the suspension forum, but figured since part of my post/question relates to track tire set up this forum may be more knowledgeable.
Anyway, on my R I will have Superpro LCA's & TyrolSport deadset with PSS10's.
I also have some Superpro Camber plates that I'm now on the fence going with vs pivoting to the Eurosport solution (mainly to mitigate potential noise issues with the metal plate).
My question relates to potential rubbing issues for those of you that have run a similar set up.
Street wheels/tires = Neuspeed RSe14 (19x8 ET45) w/ 235/35 PS4S
Proposed track wheels/tires = converting winter winter Enkei TX5s (17x8 ET45) and run 245/40s
For those of you that have run this set up/something similar can I get away with lowering (1/2"-3/4") the car a touch on the PSS10s vs stock ride height w/o risking rubbing?
Thanks in advance!
Thanks in advance!
