@Chillout and anyone else that may have some insight. I've got one of the unlocked firmware files installed (FL_8S0907159___0004_UNLOCKED_2.odx). It loaded with no problems, and should have sound in Comfort, Normal, Sport and Eco. I have no errors in the module and output test (via VCDS) works. The one adaptation the module has is set to 100%.
I have these modes configured in my driving profiles, as seen here...
When I switch modes between Eco, Comfort, Normal and Sport (or change modes using the dropdown in Custom) while looking at the measuring values of the soundaktor module in VCDS everything looks correct, as seen here. I don't know if I should see anything in "Driving profile switchover" or not. It always says no request but possibly it's a quick transient when switching over and VCDS logging resolution isn't set high enough for me to catch it. Anybody with factory soundaktor have some time to waste looking at measuring values for me?
But there is no sound in any mode. Either that or it's too quiet for me to hear. From the way people (used to) talk about wanting to disable the soundaktor I can't imaging it's so quiet that I wouldn't be able to hear it with the radio off, windows up, while specifically listening for it. I guess it's also possible I'm not
getting into the range when I would hear since this firmware has a max RPM of 8150 and my car is a diesel. But I took it to 5500 with no sound. And the GTD firmware also has a max RPM of 8150. I know you gas guys like to rev but you're not daily driving at 6000+ are you?
