Mother
- Orlando, FL
Wi
Winter setup yet uses all seasons
Seems appropriate for his geography. ?
Wi
And all season tires lose grip starting at 42 degrees. So what's your point?You are correct. If Crild knew what he was talking about, you're not supposed to use summer tires below 45 degree temps.
You can literally Google it to get the same information.Ok buddy, what ever you say. I can tell you're one of those "one upper" type of person.
good job buying the incorrect stoptech kit for your car.Picked up an ST-40 kit (83.892.4300.51) for my 2015 S3 months ago and am just getting around to a test fit. With Enkei RS-05RR (18x8.5) rims it looks like 7mm spacers will give me about 3mm clearance. I thought I'd need a different set of lines based on comments in this thread, my kit came with 950.33014 line kit, but holding them up to my stock lines it appears they should work. They might be an inch or so shorter but seems like there's plenty of slack in the stock lines. Am I missing something? Trying to avoid doing the install twice . Is anybody leaving the stock dust shields on? Thanks
My wheels are 45et, definitely weren't going to work without spacers. Maybe the 355mm rotors push the caliper out enough to give the clearance needed, I've got 328mm rotors. I watched GTI Jake's video and he explains the difference in the lines on kits designed for MK6 vs the MK7 setup. It's just a minor difference on the end that connects with the hard line, specifically the shape of the fitting which doesn't allow it to go through the bracket on the chassis. A couple minutes with a file and dremel on the bracket and it slides in like a glove. Just have to disable the brake pad warning sensor, bleed the system and button everything up.
Seems like you got it all figured out. If I were you I’d confirm with stoptech about the pistons. GTI and R have different pistons, I assume S3 will also differ from GTI. I didn’t try refitting dust shields.
