SonicBloom
- Bay Area, CA
- 2017 GTI S
What lugs are those? I've never seen a lug like that in a ball seat.
Urotuning stud conversion with their 19mm lugs.
Seems I have long missed the boat. Looks to me like Golf R part number is 896 though I don't see any 896 listed. Someone correct me if I'm wrong...
I didn't see a ball seat lug nut in that style on their site. Neuspeeds are going to take the OEM R13 ball seat bolts, so if you have conical seat lugs on those wheels they aren't safely mounted FYI.
If you look at their stud conversion kit you can choose the nut style and then also have the option for ball seat washers. I presume that's what he did.
Ah I missed that, they even highlighted some text for me and I glossed over it. Not a huge fan of those washers but if they're the right radius ball seat they should be okay.
Just call and talk to John Butler they still have ST41 and St40 in stock.
The part numbers cross from either models (I got a mk6 kit), the only difference being brake lines which they can include the mk7 lines when you order.
896 might be the mk7 R part number, but that’s not the only caliper with the same sized pistons so you’re not “risking” anything
When I was looking none of the caliper options match the sizing for the R. Which one are you saying fits?Just call and talk to John Butler they still have ST41 and St40 in stock.
If you have ball seat wheels like Neuspeeds I do not recommend a stud conversion because you will need washers. For some reason some of my lug nuts will loosen after initial tightening so I have been checking a few days after. After one re tightening it seems fine. I think this is caused by the washers.
I would get closed ball seat lug nuts to avoid using washers but no one seems to make any that’s not black in M14. Maybe also converting to M12 would give more options.
If you want to avoid this issue you could just get a wheel speed stud that you can screw in to make wheel changes easier while using lug bolts.
