StorableComa
- SoCal, USA
- 17 GSW S FWD
Thermostat is leaking with lots of obvious build up. Car is stage 1 flash with FMIC and DP. Looking for a dealer near Long Beach if possible.
Think I'll give them a try. Worse case I have to go out of pocket for it, but I'll probably buy parts from FCP and go indy shop in that case.Garden Grove dgaf.
It's pretty easy to DIY if you have the tools and space.Think I'll give them a try. Worse case I have to go out of pocket for it, but I'll probably buy parts from FCP and go indy shop in that case.
Debating doing my IS20 install, so I might try and tackle the Waterpump myself. Local indy shops charge about 400 for labor on it, so might be a nice savings. Probably pick the kit up from FCP regardless. Though their OE kit for 350ish is out of stock, not sure if I want to spend 650 on the OEM kit or just order the $285 WP/Thermo kit from ECS and do FCP if it fails again.. plan on keeping the wagon a while.It's pretty easy to DIY if you have the tools and space.
Went there to get 2 recalls done. Service writer Clayton wrote it up, got me in and out in ~1hr with a free carwash. ??Garden Grove dgaf.
I'd only go to a dealer if it was warranty work. Otherwise, there are plenty of highly qualified independent tech's in So Cal.
We're pretty blessed with a ton of excellent VW shops in north OC.Any VW specialist recommendations in Los Angeles or Orange County? I'm looking to have someone check my new used car to bring anything back to stock that's been modded so I don't have a dealer flag and void any part of my warranty.
Pacific German is also in OC. My buddy works there and he use to have a modified MK7.5 so he knows them well.Any VW specialist recommendations in Los Angeles or Orange County? I'm looking to have someone check my new used car to bring anything back to stock that's been modded so I don't have a dealer flag and void any part of my warranty.
Is your rear window already tinted? I ask because I had been looking to get mine re-tinted due to a scratch, and apparently tint shops charge an arm and a leg to remove tint prior to re-tinting (it's a lot of work)Pacific German is also in OC. My buddy works there and he use to have a modified MK7.5 so he knows them well.
Sorry for the thread jack-- Anyone know of any good tint shops around LA? I called EuroVision but they quoted me $400-$500 for my rear window and the two tiny windows up front.
Yup, mine is already tinted and has a couple bubbles. Probably why the quote is so high. The original shop wouldn't warranty it so I don't feel like going back to them.Is your rear window already tinted? I ask because I had been looking to get mine re-tinted due to a scratch, and apparently tint shops charge an arm and a leg to remove tint prior to re-tinting (it's a lot of work)
