Updates 11/10/24:
11/4-11/5: full track day prep and tech inspection. Flushed brake fluid for RBF600. Swapped the race wheels and sticky shoes on. Verified torque and condition of front end components.
Found busted RS3 brake ducts after low mileage street use and spirited drives. Culprit is likely the stock length FSB end links + slightly lower ride height (15mm) + girthy 28mm H&R FSB contacting the ducts.
Disappointing, but easy fix. Time to order new ducts from the lovely Svetlana in Latvia
11/6/24: only track day of the year, HHR (home track) in San Marcos, TX.
…Rewarding, but not without issues. I blame
@MonkeyMD for not attending, thus not letting me rub his “good luck beard.”
(#nohomo)
For full, unfiltered info on the track event, Click below…laugh and learn stuffs: https://www.golfmk7.com/forums/index.php?threads/we-tried-to-take-a-fwd-lap-record-instead-we-built-the-perfect-street-and-track-mqb….447621/
…navigate to page 3, start @ post #33, read to ~ post 38-ish. That includes you,
@tigeo
11/8/24: ordered BFI stage 1 engine mount and trans insert.
Purchased on sale from UroTuning. ETA late next week.
Have had APR billet steel dogbone insert aince 8k miles and all stock mechanicals. Did a great job, but the car has had all suspension issues sorted, so now the low integrity of stock rubber chicken mounts has revealed itself.
Goal is maintenance + final elimination of excess engine movement, for maximum traction in the first 2 gears again (DSG, deep drag race gearing from factory).
Remaining goals:
1) VCDS adjustments to ABS, VAQ and TC. System blocked me when I attempted it the first time, and I was in a hellacious time crunch. Abandoned mission.
2) IS38 w/OTS tunes from Ed Susman and co. 93, E30 and E85
3) Full paint correction and sealant (7-10 months past due).
Last job was done 6/2023 and had amazing results. Took 3 full days, though.
Can do it in 2 this time, due to better detail products and a nice DA w/5” pads.
That is all! Car is fantastic otherwise.
7 year anniversary just passed on 10/30/24, and I’m still in love with my pint-sized 3150lb Stormtrooper.
Hope you all are doing well, and loving your MQB as much as I adore mine.
