Simos Tools - New Phone Datalogging App
mr wrong
Franklin TN
No coding, and have not implemented any adaptations yet. Has been discussed adding some of the common ones, like DSG basic setting etc., just haven't gotten around to it yet!
The app doesnt so any internal unit conversion, you can do it in app...but honestly the easiest option is edit the log list csv manually and then import into the app. Here's a copy of "USA" units csv
https://github.com/Switchleg1/SimosTools/blob/master/PID/PIDList22-USA.csv
I have absolutely no idea how to do that, but I appreciate you answer.
mrmatto
Jacksonville, FL
2024 GTI DSG
I haven't been able to find a Macchina A0 in stock anywhere for a while. Until then, can the app connect to any other BT OBD adapters?
Switchleg
Edmonton, AB
Mk7
I make a0 clones, send me a dm
mr wrong
Franklin TN
Two questions..
What is the micro USB port for?
How do I import the CSV file to get standard measurements?
aaronc7
17 S3
Two questions..
Flashing firmware via PC, or using VW_Flash using PC. otherwise everything is over BLE
you want the USA units then?
mr wrong
Franklin TN
Yes. You told me where I could find the file. I just don't know what/how to import it.
aaronc7
17 S3
Oh, go to Setting
- Import PID CSV
- 22 CSV
- Select csv file
make sure logging mode is set to 22
In mode 22 logging, you can go to connection settings and max these out:
Max logging rate: 150hz
Q correction: 1ms
