Hypocrite
Then any car is a performance car
When you say "maintenance costs more on a VW," can you give me a comparison for common repairs (or point me to a website that does?Theres an argument because you all have dicks that are too big for your pants so you feel the need to swing em around in each others faces.
Facts:
Maintenance costs more on a GTI than an average car. It's German.
All cars have some issues. You will never buy or drive a car that doesn't need repairs at some point.
The GTI is considered a performance car, while also being economical.
If you use throttle control, you wont spin the tires. Any lightweight, FWD car with a decent amount of torque and tires that don't stick will have some slip if you give'er'wah.
Different tires, different roads, different wheels, different cars, will all have different levels of road noise. Some people have more tolerance than other to sound. For example, I'm sitting here having an aneurysm because the maintenance department has a heavy trigger finger on the high pressure air blowoff tool, and my coworker sitting next to me couldn't care less.
Now put your dicks away. You look foolish and nobody else wants to see them.
The official 0-60 is something like 5.7 sec. There are many SUV's that can beat that.
Sent from my SM-G930V using Tapatalk
I don't think maintenance cost that much more on GTI compared to other cars, maybe just added DSG service...let's see:
-every 10k or yearly oil change
-every 20k cabin filter change
-every 40k DSG service
-every 60k spark plugs (may have changed this to 40k intervals for new models)
-every 60k engine air filter
-every 10k tire rotation
-every 2 yeras brake flush (first one after 3 years)
I don't buy this stigma that it's maintenance intensive because it's German and unless you maintain it religiously it will fall apart.
I would check differences on auto parts websites. Common maintenance to me include things like brakes pads, wheel bearings, bushings etc. For example, full car brake pad replacement on my Camry costs me 50ish dollars, while on the GTI costs me around 90 bucks. Thats based on prices for OEM replacement parts from O-reilly. I can't say for sure if the prices are that big a difference between other popular hot hatches but when I say "normal cars" I mean cookie cutter, run of the mill sedans that you see all over the streets. I also didn't specify "maintenance costs more on a VW", I specified GTI since I'm sure the Jetta base model parts are cheaper than the GTI equivalents
i think comparing maintenance of a GTI vs regular cookie cutter cars is an incorrect comparison and results wont tell you what youre looking for. a better comparison would be maintenance of a GTI vs SI vs FoST(i would include wrx but i think it being awd might make maintenance costs different?)
so, your benchmark is "how well does it drag race"?
How do you go around corners, with those blinders blocking your vision?
