tigeo
- Richmond, VA area
Here is some info etc. from my second HPDE experience at VIR with the PCC Audi Club.
Car:
Tires. The PS4 all seasons actually do v. well for a novice driver like me, the main issue is melting/chunks/wear from the lack of camber and my novice driving skills in some corners – these are not cheap so trashing expensive daily all seasons is the main issue with these as I see it. I didn’t notice any issues until the last 2 sessions where I was solo and pushing the car harder as I got more comfortable. I started getting some braking issues where the ABS/ECS was kicking in b/c the tires were losing traction. I think I found the limit of these tires.
Power. No issues. This car has more than adequate power for HPDE. With an IS38, FBO, etc. this thing rips. I was able to touch just over 130 on the back straight which is fantastic for station wagon! The United Motorsport Haldex tune is a great add for pushing power to the rear wheels and I attribute being able to power out of turns in-part from that upgrade.
Brakes. For my first HPDE in 2020 I didn’t have adequate brakes and lost a full day/4 sessions b/c of it. This year I had the APR BBK and it was phenomenal. No braking issues with their middle “advanced street/entry level track” pads. I did use about ½ the pad however so like tires, the cost of using non-track focused gear is high and at some point, it’s cheaper to pay the bucks and get track stuff vs. hammering your daily gear. Fluid was Motul RBF600. Rears are stock 272mm solid rotors with EBC Yellowstuff pads and ss lines. I have the RS3 ducts up front and kept dust shields (modified 340mm) when I did the BBK. I never approached overwhelming these brakes.
Handling. Car handles fine or at least at my driving limits. H&R Sport springs, Bilstein B8s, and a H&R rear sway bar. I did find towards the end of the event I was getting a loud spring groan noise on the p. side during full compression in T17. Likely just coil on coil noise with some side load under the g’s in that turn – I note that some H&R springs will have rubber coated coils in some places likely for this reason. Car goes over curbs great and has plenty of compression travel with the mild lowering/sport springs. I’ll call my set up a “sport touring suspension” which seems to be great for HPDE.
Seats. They lack bolstering in this base model cloth jobs but my instructor showed me the trick of locking the belt and sliding forward. Solved all my problems of not being able to stabilize myself in the car.
ECS/ASR/etc. I drove it with ECS Sport the whole time. I can turn it off as I’ve coded the button with OBDEleven to mimic the standard settings on the Golf R but I’m not having any intervention at this point. I have my XDS set to “weak”. All other settings are stock.
My instructor noted “Car works great. Responsive and great prepared for HPDE. Lots of power and good brakes.” When we first met up he asked about my car and I noted I had all season tires he responded “goooooddddd”.
Upgrades for next year:
Tires. I will be getting some wheels and mounting up some more appropriate tires. Really struggling here but think I will just go up a notch incrementally to some PS4s at this point. The nice thing is I can use those most of the year here in central VA on the street vs. a 200tw track-type tire. At some point if I continue to do an event or two a year and my driving progresses, I’ll get some 200s; with a wagon it’s easy to carry extra wheels to the track or with many of these they would be fine to drive, I just don’t want to daily tires like this as you sacrifice daily comfort.
Suspension. I need some negative camber and will be adding some fixed plates (034/Superpro) or possibly the Eurosport mounts w/inserts as a mild upgrade. I’d like to keep NVH to a minimum but realize you can’t have your cake and eat it too.
Brakes. I’ll try out APR’s “advanced track day” pads next time and just swap them in/out before the event. The one negative about the APR BBK is that it doesn’t utilize the quick change from the back of the caliper system – have to pop the calipers off.
Data logger: I need to research this but I hear Harry's is good and will work with your phone/GoPro or lap timing etc.
Driver:
I was overall much more comfortable with the whole HPDE thing this go around which made for a much more fun experience overall than last year. With the Audi Club, I’m in the green/novice group and would likely continue in that group for another event or two. Getting to go solo or two sessions was great. Never felt uncomfortable or had any on-track drama. Never had passing drama worth a mention...it's the novice group, patience is important. Instructor was good - no BS/to the point.
Eyes up is an issue for me, as I get more comfortable I’ll begin to be able to look through turns more vs. the brake zone in front of me.
My plan for 2022 is to do both Audi Club PCA events, one in March at Summit Point and the fall finale at VIR in Nov.
Here is my packing list in case anyone is interested:
One of my solo laps, 2:30 is about as good as it got:
2021 Audi Club Fall Finale at VIR - Green Group last session day 2. - YouTube
Car:
Driver:
torque wrench w/17mm socket + short extention |
air pressure gauge |
1 qt oil |
1 jug coolant |
1 bottle brake fluid |
Liquimoly Speed Tec (2) |
ethanol cans (2) |
pour hose |
funnel |
rags/towels |
glass cleaner |
work gloves |
nitrile gloves |
safety glasses |
tow hooks |
race numbers |
window numbers |
sunglasses (2) |
helmet |
long sleeve shirts |
sun block/lip balm |
chair |
cooler |
drinks/snacks |
Bluetooth speaker |
headlamp |
GoPro + mount |
med form |
Speed Waiver (track) |
waiver (Audi Club) |
tech form |
track insurance |
