DerHase
- Hampton Roads, VA
- 2019 GTI Rabbit
I have KW rear adjusters (Bc were back ordered) and 8in 350lbs springs to go with my stock fronts, but they have been sitting in my garage for too long. Going for some flat ride to smooth out the chop on back roads.
ill probably go to koni str.t (available 2025 for the golf) or tein enduapro plus (i bit leery but hydraulic bumps tops could be nice) with those febi / volvo front bumps once i need to replace the shocks and struts.
Are the rear bumbstops also active during hard driving and has anyone tested the rate?
Rears I trimmed 10mm off the tops. I'm not sure that they're as active as it would normally induce oversteer (not great for common idiots drivers).
I trimmed 10mm to settle bouncing after lowering. Wasnt *terrible* but it is better to live with on the highway.
I have a pair of DSG R front springs in the garage if you need them. I was planning on replacing the front APR's and keeping my rear MSS adjustable setup before I sold the car.
I'm pretty impressed with the DCC shocks on the mk8, so I'm going to try to work within that limitation. Is the Mk8 R lower than the GTI? Maybe I just buy a set of mk8 R fronts and same same with the BC rear setup. Wil it accommodate swift springs?
Will def take those off your hands, shoot me a PM with your price. Also happen to have the exact part number?
Yeah I have used swift springs and Eibach 2.5in springs on BC perches on a past car.
I think BC uses 62mm springs, but anything from 62mm or 2.5in (63.5mm) will work just fine.
