Laminex Headlight and Hood Edge Clear Bra.
I purchased both thru ECS Tuning.
Headlight film was around $58. This includes fog light film if you decide to do.
The front edge hood bra was something like $140. I think.
The clear bra extends about 6 inches up from edge of hood.
From 5 feet away it is hard to see. I can find it because I know it is there.
I feel this is a must for any Golf head light. The cost is so small and protection so good.
The clear bra costs more but is also a must for protection.
They make a full front kits that are around $350. Little more than I want to spend. I would like to do the front edge of bumper, where the bugs collect. Maybe the front edge of the lower white spoiler also.
Pulled from Laminex Headlight and Fog Light Thread. (My writre up)
I have been meaning to do a write up on my build thread but have not washed car in 2 weeks to take some pictures.
I installed Laminex leading edge clear bra on hood and also head lights. My past experience with installing film was on our front door with frosted film and some house windows using UV film. The clear hood bra installs like the house film. Clean car, spray hood location, peel and spray back of film, apply position and slowly work out from center. I found the hood film easier. Will provide good protection. They also make a lower clear bra but this is bigger than I want. I would like a piece that fits the flat part only of bumper. This is the location that collect and most bugs.
Headlight film. Read directions first. On the headlight film, clean the head lights. Remove film backing and then only spray the head light with light soap solution. The less water the easier. The headlight film had to bend more so it does not stick down until all water is out from behind film. This takes time so be patient and stick with it. I almost gave up. I used a can of compressed air to help blow behind film at edges to remove liquid and dry film so it sticks. Just do not blow hard. Light touch. If you can not get liquid out, lift edge and blow more. Use the tool they send with felt on outside. If you press to hard with direct plastic tool you might scratch film. I did not use but if you have a lower temp heat gun, try but do not get close. Main goal is stick with it. As you get the fluid out from under film it will stick. Until then keep working.
When you apply, get the headlight film lined up. It does not slide as well as bra hood film. Also using less fluid it will not move as well.
Install when you have time. Maybe do one and then take a break.
Headlight film is tough and will protect light well.
You will not get all air out and may have some trapped fluid. Try to get air out that island R than 1mm. Once you are done, leave some for 24 hours. If possible park car in the sun so headlights face sun. The sun will clear up and smoky look from fluid and will help remove
Small bubbles. After 24 hours go in the needle and carefully PPP blister and remove air. Poke the film but do not hit light. Go slow. The film will become clear and smooth in the sun.
I had to trim the edges and plastic tabs off when installed. Use the craft cutting blade they send and cut about half way they film then try for peel off. Do not cut all the way thru or you will cut your light. Light touch.
I think these films are a must. The headlight film it stought.
When you look at head light after a week it looks about 99% normal. You can see slight distortion but only time I can see it from behind the wheel is when I pull in next to garage door at an angle and to the side you can see light distorted some. On the road I can not tell. At night looking at light it looks good.
If the film bothers some then how will they like their lights when they are pitted after 6 months. I feel the slight trade off is worth the protection for my $1500 LP lights.
The hood bra can only be seen once you get within 5 ft of car. Then you can see the upper edge. But again it is worth it for protection. Make sure hand are clean when you peel off and apply film. The back side is sticky and will pick up things. Do in garage or on a non windy day.
I used unscented baby bath soap to mix solution. I think the headlight film comes with a small sprayer and the hood is a larger sprayer. Use the larger sprayer.
Bottom line. Get the film and protect the car and head lights.
When time I will take pics and post. However it fits in so well you might not see anything.
