sandmangti
Christmas Fog!
Did you make a hole in it for the 12v socket?ECS Tuning Center Compartment Tray.
Picked up the new tray once they came out with it for the GTI.
No secret that the tray is made in China as it is on the box in bold print. The tray is solid and good thickness. Is a friction fit as it does not move around and to pull out you push from the inside on each side and lift out. Not hard but the fit is well enough that you can not just pinch a divider and pull out. This is good as the tray will not move around in driving. I purchased one for my wife’s car and any downward pressure on the tray and it would drop down in pocket. The ECS GTI tray is solid enough you could turn in upside down on the ground and stand on it. Comes with rubber inside pads with ECS logo. Don’t want logo? Use rubber pads as a templet and trace out some adhesive felt. Line each pocket with felt to cushion moving parts.
ECS has this part right if interested.
Sent from my HTC One M9 using Tapatalk
DCC Shocks holding up with the Pro Kit?
That looks clean man! How long did it take to install?
