Replacing Laminex Film.
About two years ago I installed Laminex headlight film and front edge hood film that are precut from Laminex. Info on install earlier in my build thread.
I am working on removing so I can install a new hood edge piece and new headlight film, this time trying a light tint. Using my 2 stage heat gun on low setting I warmed up an corner on the hood edge film. Heating and pulling I worked across in about 5 min. All the glue came off. Hood paint under looks good. Have not cleaned yet as it started to rain.
The headlight film is super thick. Offers a lot of headlight protection. I also heated a section to get started. Pulling ery lightly on one edge I moved heat gun up and down. With light tension the film comes off ones heat level is reached. If you pull hard before film is heated adhesive is left behind on head light.
The only part that adhesive remained no matter what I did was the upper edge. And lightly around the edge of the film. I think the exposure to the sun on top made for stronger adhesive bond.
I was going to try Oops! But was out. Using soap water, window cleaner I use on tinted windows, some WD40 and MF cloth I was able to remove adhesive with no issues to head light.
Will work on install of new film this week.
