Mine arrived!
My first thought was to go safe and order black.
Then I like the silver.
Finally I picked the red to add some color to interior.
The red as shown on Ebay looked like a bright red but the color is a little more calm.
I still like.
After reading about other installs and suggestion to use two wasy auto tape, I had planned to go that route. Looking at the paddle extension they fit the OE paddles perfectly. I felt adding the 2 way tape might not look as good due to it spacing the extension out more from OE paddle. It would not affect use but looking at the set screws I decided to install them as designed and not use the two way tape. If I could find very thin tape then that might be a good option, but the tape sold near me is thick (1-2mm).
How does it work and feel?
They are not small. It will take some getting use to seeing them spin around while driving.
At the 9 and 3 position they shift as well as OE, maybe better with less effort. I also do not have to locate the paddle like I sometimes do on the OE set up.
At 10 and 2 position you can shift the paddle all the way out to very tip.
Feels good not having to drop hand down to shift when I hold wheel in this location.
At 8 and 4 postion you can still shift but you are using the part of the paddle extension that is closer to the OE paddle. You can not go to the very bottom of the extension and shift. The angle is to far off to get leverage.
Not an issue but just for info.
Bottom line, I really like.
I like the look. They are big but remind me of the paddles used in cars featured in "Need For Speed" Movie.
In driving it takes less thought to locate the paddles. With the OE I find I search for the paddles. Not a big issue but the extensions just make it better. I also thought the set screws stood out too much in pictures but in person they are very small. Very Small.
In my picture you can see they do not show up a lot.
Sold on Ebay by dealer hiuda123.
Tittle - VW Golf R GTI Scirocco
Cost - $69
Specify in note section color and if you want company logo on or off. Mine are left off.
Get you some!
