s7wag
- Bedfordshire, UK
Just a heads-up based upon first-hand experience. I've recently gone through the process of fitting VWR springs (professionally) with spacers/extended bolts front and rear.
Last night my wife and I were off to London to see a show - journey around 45/50 miles to Hammersmith in London. Just got off the M4 by Heathrow to join the A4 (after journeying down the M1 and around the M25 orbital) and what appeared to be front offside suspension knocking noises started. Seemed to be OK in smooth surfaces but any holes/un-even surface and front offside (drivers side) of the car seemed to knocking/rattling. Bear in mind the VWR springs had been fitted middle of last week - four days previous. I suspected some loose fixing bolts...I did a visual check, pulled the wheels about and checked lock to lock - couldn't see anything. We continued slowly to get to and park outside the Novotel whilst we then went off to the "Dynamo" show...whilst preparing for VW Roadside Assistance at 10pm.
Anyway, great show and walking back to the car we called VW Assistance. Said they'd be there in the next 55 mins and will call 10 mins before arrival. 20mins later we got the call and the AA man was there 5 mins later...
Quick road test in the service road of the hotel and car then jacked-up....suspension all looks fine BUT front extended wheel bolts had all come loose!!! Now I know they were all torqued up to 110nm (as I watched it being done).
He then checked all the other wheels and all bolts although tight were not at 110nm still. He told me this was common when using spacers and after-market extended bolts. He also suggested using thread-lock (lock-tite) on three of the wheels bolts as another counter measure.
We were LUCKY so a heads-up for you all - if you're using spacers make sure you check the wheel bolts regularly and ensure they are at correct torque setting. If it doubt also apply some thread-lock to at least two/three of the wheel bolts..
Steve
Steve
