MiamiBourne
- South Florida
- 2016 6MT Golf R Oryx
In need of some forum help. Recently i started having a warning flash in the MFD and audible signal (dinging like the door is open or seat belt is off). The MFD immediately starts flashing the car logo and occasionally lights red in the hatch area. The warning chime only goes when I hit the throttle and beeps every second continuously. The chime stops when i come to a stop, but the MFD continues to flash the car symbol.
My hunch is this is a latch, camera issue as it may be sensing my hatch is open when it really is not.....?
i scanned and came up with the following to faults. i have disconnected the battery, the fuse to these parts and all the connectors to the camera and latch....no help....
any ideas?
Does your MFD do something like this?
https://youtu.be/KcnA1etSv3s
My issue was actually the Trunk LED Strip DIY that I followed from you. For some reason the LED Trunk Strip combined with tapping into the deautokey LED Trunk Light housing didn’t like each other.
So I had to remove the LED Trunk light housing and put the OEM one back in with the trunk strip adapter.
Anytime I opened the glove box or turned on the dome light for all lights the MFD would light up with the hatch blinking. Maybe it started when I added the footwell LED because it wasn’t like that when I first installed the trunk strip.
Seems like something else electrical is causing your issue.
