Rs3 Coilpacks not working
If I needed coils I would actually get them from APR since they are very close in price as OEM. And I'm not one to recommend APR.
2slowvw
Moderator
VA
2022 Tesla Model 3
After checking spark plugs and coils making sure everything is good. You can take note of your coils and swap them to different cylinders and see if the misfire follows the coils. If not do the same thing with the spark plugs.
FlyingNugget
Toronto, Canada
Check connections, and check your plugs. Might as well replace the plugs since they're relatively cheap. I am running RS3 Plugs/Coils and the car runs great *knock on wood*
Elcheapo Loco
CA
Don't shotgun parts when you haven't pulled the codes. You have the same symptoms after changing the coils so they are not the cause. At this mileage I would suspect carbon buildup is causing the misfire.
