RPM Changes with Clutch Changes in Neutral
jhbjrpdx
Portland OR
2020 GTI 6M
So I noticed that when idling that when I put in and release the clutch without going gear I get small changes in the RPMs. I tend to put it in neutral when I am at a long light so when I saw it the first time I experimented and can replicate the effect. I can hear the tiny rev change too. Seems like when I do it a few times, the revs stop changing. What am I seeing here?
Thanks
JHB
okMK
AZ
16 2dr MK7
The ECU assuming you are putting the car into gear and letting off the clutch, it raises the RPM to compensate for the take-off. If you notice, the car doesn't detect what gear you are in until you are pretty much completely off of the clutch.
just kidding, you have crank-walk... part out.
Are you sure you have the clutch fully depressed? Not even letting up a little bit?
Ridebjj
lasVegas
This happens to me and has been such for as long as I can remember. Rpms rise about 200 rpm with clutch in. I'd have thought it's because when you clutch in, you're not spinning the tranny shaft (giggle) anymore, no?
Nineeightyone
2019 GTI | 2004 JSW
2019 here, same behavior. I'm pretty confident that it's just due to load changing slightly and the ECU compensating, as others have said.
FlyingNugget
Toronto, Canada
Mine did this completely stock, and still does with aftermarket everything.
