RGB Ambient Lighting (hopes/dreams)... pre-facelift Mk7
ibar19
France
Golf 7 gtd
Okay, if you have Farbe 4-10 I am confident we can get the full slider working for you. Full adaptation list will make things easier.
Do you also have ambient list 2 with Farbe 11-30? Some BCM's have it, some don't depending on software.
I am not from 11 to 30 on the ambient list 2nd gen (already coding on a friend's facelift)
However Farbe 4 to 10 is written "E1" everywhere and I can only code 2 digits/letters (E1 = ok, FF=ok, 99= ok but 255= rejected
ibar19
France
Golf 7 gtd
Probably ODIS is showing the value in Hex.
Hex E1 = 225
Hex 99 = 153
Hex FF = 255 (which is the max)
http://hextodecimal.com/index.php
I don't think so because I've already coded the 30 color ambient lighting on a GTI TCR with odis and it wasn't in Hex, and farbe 1 to 3 are in dec. to try.. but I'm stuck on this point the :/
there is no one on the forum who has a passat with ambient lighting that could give its complete adaptations? ^^
Cuzoe
Might be that BCM shows one thing even though the real value is something else. Might also be different with different BCM software. My guess is that TCR has full facelift BCM (with all 0's for long coding). Your BCM seems to have long coding but also show the color slider. My BCM has long coding, and no color slider.
Your car is a Passat? Or a Golf? Probably doesn't matter much for BCM, but just curious.
Anyway, the following channel enables the color dropdown on my BCM. I don't know if facelift BCM's have this adaptation.
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI
00000001 - White
00000010 - Warm White
00000100 - Orange
00001000 - Red
00010000 - Blue
00100000 - Turquoise
01000000 - Did not add another color
10000000 - Did not add another color
Each bit enables a color, but the adaptation value is entered as decimal, so...
To get white, warm white and orange (111) enter 7
To get white, red and blue (11001) enter 25
To get white, orange, turquoise (10101) enter 21
ibar19
France
Golf 7 gtd
00000001 - White
00000100 - Orange
00001000 - Red
00010000 - Blue
my car is Golf 7 GTD, (have to change the golf image so as not to have a black background in "mood lighting" I chose a passat image because golf facelift was too dark.)
I managed to activate the pre-established color list (off, warm white, red, turquoise)!! It doesn't change anything (I don't have an rgb bulb) and it doesn't change the "blue" of the MIB2 screen either.
Here is the list of my adaptations to get here:
and before what i had (facelift type slider):
now how to modify the strips of the MIB ...
  • eclairage d'ambiance style passat.txt
  • CURSEUR COULEUR.txt
Cuzoe
I'm not sure your BCM supports changing the MIB strips. My MIB strips do not change with color, even though my RGB bulb changes (one bulb, connected to test).
Maybe a couple days before I get to look through your adaptations. I am now at the hospital, wife is in labor ?.
mr-fix
Poland
Audi S3 8V Sedan
I was struggling with enabling this additional background light menu for a year now. And today I finally made it. Hint: if you have pre-facelift MK7 you will need to change 5F coding from 027302 to 027312 (this is for MK7 Variant/Wagon).
Pre-facelift graphics do not include ambient illumination menu elements and configuration.
ibar19
France
Golf 7 gtd
I was struggling with enabling this additional background light menu for a year now. And today I finally made it. Hint: if you have pre-facelift MK7 you will need to change 5F coding from 027320 to 027321 (this is for MK7 Variant/Wagon).
Ok. So with this coding in 5f. the strips on the discover change color ? I think i was already try this. But the color is red or blue.
Cuzoe
No. I have not found a way to change strips on the discover (mib) via the menus. They will change to red if you if you set your MIB theme to GTI. That's in 5F long coding byte 18.
It's 5 am where I am so I'll explain later why I don't think it's possible to change MIB strips using menus in pre-facelift. So on a facelift BCM there are actually two RGB color lists (10 colors or 30 colors, depending on BCM software). The reason for this is explained here. To summarize that link... one of those lists dictates what will be shown on the screen in the slider, the MIB (strips/accents), and on the digital dash (if you have it). The other list is the values that will be sent to the RGB LED's if you have them. LCD screens display colors differently than actual LED's so there are two lists. Prefaclift BCM's do not have a list for screen color. So I don't think you will ever see the strips changing.
@mr-fix Please post pictures before and after the changes you made. Respectfully, I don't want this thread to have unclear information. In post #5 I give details on the adaptation channel changes needed to show the lighting graphics (assuming your MIB supports them). The information you provided depends on that previous information but does not mention it. Changing the 5F long coding Byte 0-2, as you mention, will not give you a lighting menu. In fact it changes the vehicle type that is shown throughout the MIB menus. And of course the possible options for those bytes will be different depending on your MIB software. The lighting menus are a separate thing.
In my first post I stated that the lighting graphics must be supported by your MIB II. And that I don't know exactly which software versions have support. You say "pre-facelift graphics do not include ambient illumination menu elements and configuration." Okay, what software version is pre-facelift? Or what is the earliest facelift software? Without that info your "hint" that suggests lighting menu is tied to those bits is creating confusion in a topic that is already confusing in several ways.
mr-fix
Poland
Audi S3 8V Sedan
@Cuzoe
My original 5F coding in byte 0-2 was 02 73 02 - this is VW Golf MK7 Variant.
This settings forces MIB2 to use assets from skins/skin0/Data/0203070200.
New coding is 02 73 12 - VW Golf MK7.5 Variant. This is linking assets from skins/skin0/Data/0203070201.
Both 5F codings will show "Background light" menu. But if the variant is set to pre-facelift, the menu will have no controls and no car interior image (check attachment - old photo made when running pre-facelift P0245T firmware).
I compared those two folders (0203070200 and 0203070201) and in my case (currently running firmware P0478T) GenericCarAdjuster directory for pre-facelift contains only information about Climate. Where facelift directory contains both Climate and AmbianceLight (check attachment here as well). This explains why pre-facelift coding will not show ambient light controls in the Background lighting menu.
Finally: I copied the AmbianceLight folder from Passat B8 directory into the MK7.5. This showed me total of 5 cogs (another attachment).
spikes92
Pescara
Golf 7.5 GTD
Good evening, thanks for all your information. I have done this retrofit on golf 7.5 gtd.
Ioo I had a bcm CF which had no pin 29 then I changed it to CG and I installed 14 rgb leds (passat audi seat mix) The lamps turned on and I can change the rgb colors in the whole car but it did not have the adaptation KOPPLUNG on CG then for a year I had it without color change at the guide profile change. I flashed the bcm in CQ and now I have automatic mode and all the necessary adaptations. I have activated everything but it does not change me when I change the driving profile. when I set automatic only the color set on profil 0 is set and if I change profile it does not change the color. I have also activated PFA amb in 19 does anyone know what it can depend on? is 19 3q0 ?. then i can't figure out how to display the light in the door pockets and dashboard light thanks
Cuzoe
@spikes92 I think we should start a separate thread. I'm more than happy to help, especially as I will soon have a facelift BCM. But since you have a facelift car to start this thread does not really apply.
I'll start a thread later tonight with your post quoted unless you get around to it first. In the new thread it would help to post a current auto scan. And also adaptation maps for 09 and 19.
spikes92
Pescara
Golf 7.5 GTD
Ok @Cuzoe se vuoi posso aprire una nuova discussione ma posso dirti che tra bcm prelift e postlift non cambia nulla.. l'unica differenza è quella che hai scritto su Kopplung che però non è in CG quindi ho flashato in CQ per averli così puoi flashare il tuo bcm invece di cambiarlo.. Comunque per rimanere in argomento vorrei chiederti come hai fatto ad attivare le luci nell'hmi del cruscotto e delle tasche? hai mappato il file gcaA? hai inserito i file del passat? puoi spiegare come hai caricato i nuovi file? ho la sequenza di verbaunformation hmi e menhafrbig ma quelle luci non escono ... e chiedo anche a @mr-fix di far apparire i soli mentre ha sostituito la cartella passat? me lo puoi mandare per favore? grazie ... Il mio codice è casuale per i test
Code:
    SW:5Q0-937-084-CQ   HW:5Q0-937-084-CG ---  Centrale elettr. --- SA: 31347
    Componente:BCM MQBAB H   H34 0251, Codifica:000000000000000000000000000000000000000000000000000000000000
    EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
    Luned�,02,MAGGIO,2022,21:04:34:16365
    Versione del VCDS: ITT 21.9.0  Versione di dati: 20211111 DS330.0
    VCID: 094F9D3909BABC93F0B-805C
IDE00001-ENG99061-Modo Produzione-Controllo accesso,non attiv. ,3
IDE00001-ENG115730-Modo Produzione-Illuminazione esterna,non attiv. ,3
IDE00001-ENG112304-Modo Produzione-Heckwischer,non attiv. ,3
IDE00001-ENG98647-Modo Produzione-Illuminazione interna,non attiv. ,3
IDE00001-ENG115729-Modo Produzione-Scheinwerferreinigung,non attiv. ,3
IDE00001-ENG115731-Modo Produzione-Virtuel_pedal,non attiv. ,3
IDE00002-Modalit� trasporto,attiv. ,1
IDE00820-Attivazione e disattivazione di tutti i messaggi di sviluppamento,non attiv. ,1
IDE01550-Posizione di Service,170.494336 ᄚ,2
IDE02152-Comportamento in modalit� produzione,2000 ms,4
IDE02269-MAS04382-Segnali di conferma-Conferma ottica alla chiusura delle serrature,Decelerazione ,10
IDE02269-ENG116666-Segnali di conferma-Akustische Rueckmeldung entriegeln,non attiv. ,10
IDE02269-ENG116669-Segnali di conferma-Akustische Rueckmeldung global,non attiv. ,10
IDE02269-ENG116670-Segnali di conferma-Akustische Rueckmeldung Signalhorn,non attiv. ,10
IDE02269-ENG116667-Segnali di conferma-Akustische Rueckmeldung verriegeln,non attiv. ,10
IDE02269-ENG122187-Segnali di conferma-Dauer der Akustischen Rueckmeldung vom Einfachhorn,breve ,10
IDE02269-ENG122188-Segnali di conferma-Menuesteuerung akustische Rueckmeldung,non attiv. ,10
IDE02269-ENG122995-Segnali di conferma-Optische Rueckmeldung 3.Bremsleuchte,non attiv. ,10
IDE02269-ENG116668-Segnali di conferma-Optische Rueckmeldung Komfortschliessen,attiv. ,10
IDE02269-ENG133344-Segnali di conferma-Quittierton bei zweitem ZV-AUF-Befehl,non attiv. ,10
IDE02269-ENG133345-Segnali di conferma-Quittierton bei zweitem ZV-ZU-Befehl,non attiv. ,10
IDE02269-ENG142248-Segnali di conferma-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Segnali di conferma-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Segnali di conferma-ZV-Blinken_Hellzeit,300 ms,10
IDE02332-Disattivare modo di produzione,0 ,3
IDE02488-Impianto antifurto volumetrico (DWA),100 %,1
IDE02711-ENG116690-Tergilunotto-Automatisches Heckwischen,non attiv. ,8
IDE02711-ENG133397-Tergilunotto-Einzelansteuerung Heckintervallwischen,non attiv. ,8
IDE02711-ENG133395-Tergilunotto-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Tergilunotto-Einzelansteuerung Heckintervallwischen Zeitintervall 2,30 s,8
IDE02711-ENG112304-Tergilunotto-Heckwischer,logikgesteuert ,8
IDE02711-ENG114947-Tergilunotto-Heckwischer Weiterlauf,non attiv. ,8
IDE02711-ENG114946-Tergilunotto-Komfortwischen Heck,attiv. ,8
IDE02711-ENG116695-Tergilunotto-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Tergilunotto-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Tergilunotto-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Tergilunotto-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Tergilunotto-Menuesteuerung Komfortwischen HW,attiv. ,8
IDE02711-ENG154784-Tergilunotto-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Tergilunotto-Traenenwischen Heck,attiv. ,8
IDE02711-ENG154831-Tergilunotto-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Fari direzionali statici:-Angolo di sterzata: offset,0.3 ᄚ,16
IDE03638-ENG116677-Fari direzionali statici:-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-Fari direzionali statici:-bei Rueckwaertsfahrt,Entrambi i lati ,16
IDE03638-ENG116675-Fari direzionali statici:-Soglia di velocit� minima,0.0 km/h,16
IDE03638-ENG116682-Fari direzionali statici:-Maximaltemperatur,100.0 ᄚC,16
IDE03638-ENG116679-Fari direzionali statici:-obere Grenztemperatur,95.0 ᄚC,16
IDE03638-ENG116681-Fari direzionali statici:-Oberer Lenkradwinkel,120 ᄚ,16
IDE03638-ENG116680-Fari direzionali statici:-untere Grenztemperatur,80.0 ᄚC,16
IDE03638-ENG116678-Fari direzionali statici:-Unterer Lenkradwinkel,80 ᄚ,16
IDE03638-ENG116676-Fari direzionali statici:-Soglia di velocit� massima,40.0 km/h,16
IDE03638-ENG116674-Fari direzionali statici:-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Fari direzionali statici:-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Attivazione adeguamento circolazione sinistra/destra,non attiv. ,1
IDE04927-IDE01446-Sbrinamento cristalli-Riscaldamento del parabrezza tempo di funzionamento,600 s,11
IDE04927-ENG126847-Sbrinamento cristalli-Abschalttemperatur fuer Frontscheibenheizung,35.0 ᄚC,11
IDE04927-ENG126846-Sbrinamento cristalli-Abschalttemperatur fuer Heckscheibenheizung,35.0 ᄚC,11
IDE04927-ENG142251-Sbrinamento cristalli-Frontscheibenheizung _maximale_Dauer,0 s,11
IDE04927-ENG142035-Sbrinamento cristalli-Frontscheibenheizung_LED_direkt,non montat. ,11
IDE04927-ENG142018-Sbrinamento cristalli-Frontscheibenheizungsansteuerung direkt von externem Algorithmus,non montat. ,11
IDE04927-ENG126845-Sbrinamento cristalli-FSH Automatik,attiv. ,11
IDE04927-ENG115736-Sbrinamento cristalli-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG141955-Sbrinamento cristalli-heizbare Heckscheibe,montat. ,11
IDE04927-ENG142021-Sbrinamento cristalli-Heizbare_Frontscheibe,non montat. ,11
IDE04927-ENG116620-Sbrinamento cristalli-Temperaturabhaengige Einschaltzeit FSH,attiv. ,11
IDE04927-ENG116619-Sbrinamento cristalli-Temperaturabhaengige Einschaltzeit HSH,attiv. ,11
IDE04927-ENG141962-Sbrinamento cristalli-Waschduesenheizung,montat. ,11
IDE04927-ENG154810-Sbrinamento cristalli-window heating front activation time pause,240 s,11
IDE04928-MAS01577-Protezione antifurto-Riscaldatore di stazionamento,non montat. ,8
IDE04928-ENG115867-Protezione antifurto-Akustischer Alarm Signalhorn,non attiv. ,8
IDE04928-ENG115864-Protezione antifurto-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Protezione antifurto-Impianto antifurto,attiv. ,8
IDE04928-ENG154588-Protezione antifurto-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Protezione antifurto-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Protezione antifurto-DWA Alarmverzoegerung,non attiv. ,8
IDE04928-ENG115812-Protezione antifurto-DWA Camper Modus,non attiv. ,8
IDE04928-ENG142007-Protezione antifurto-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Protezione antifurto-Heckscheibenbruchsensor,non montat. ,8
IDE04928-ENG142006-Protezione antifurto-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,si ,8
IDE04928-ENG142249-Protezione antifurto-OBD Alarm,activ ,8
IDE04928-ENG154722-Protezione antifurto-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Protezione antifurto-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),no ,8
IDE04928-ENG142010-Protezione antifurto-Sensor_fuer_Innenraumueberwachung,si ,8
IDE04928-ENG115866-Protezione antifurto-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Protezione antifurto-tilt_sensor,si ,8
IDE04928-ENG126842-Protezione antifurto-Ueberwachung Innenentriegelungshebel,non attiv. ,8
IDE04928-ENG115868-Protezione antifurto-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05144-Lettura indirizzo parametri,00 00 00 ,3
IDE05145-Configurazione delle luci,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA: sensore di inclinazione del veicolo,100 %,1
IDE05823-Impianto antifurto volumetrico (DWA): serie di parametri,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 ,172
IDE06089-ENG141976-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 ᄚC,30
IDE06089-ENG115738-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 ᄚC,30
IDE06089-ENG115737-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 ᄚC,30
IDE06089-ENG115740-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 ᄚC,30
IDE06089-ENG115739-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 ᄚC,30
IDE06089-ENG115742-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 ᄚC,30
IDE06089-ENG115741-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 ᄚC,30
IDE06089-ENG115744-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 ᄚC,30
IDE06089-ENG115743-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 ᄚC,30
IDE06089-ENG115746-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 ᄚC,30
IDE06089-ENG115745-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 ᄚC,30
IDE06089-ENG115748-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 ᄚC,30
IDE06089-ENG115747-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 ᄚC,30
IDE06089-ENG154774-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG141977-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Sitzheizungsfreigabe,non montat. ,30
IDE06089-ENG154785-Abbinamento dell'assorbim. elettr. per livelli riscald. sedile-Spannungsoffset SIH_75,15.0 V,30
IDE06425-Modalit� banco di prova a rulli: funzionale,non attiv. ,1
IDE06507-MAS13125-Tasto nella console centrale-Funzione tasto 1,start/stop ,8
IDE06507-MAS13129-Tasto nella console centrale-Funzione tasto 2,non codificato / non montato ,8
IDE06507-MAS13132-Tasto nella console centrale-Funzione tasto 3,Programma di guida ,8
IDE06507-MAS13135-Tasto nella console centrale-Funzione tasto 4,non codificato / non montato ,8
IDE06507-ENG140243-Tasto nella console centrale-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-Funzione di climatizzazione/riscaldamento mediante telecomando-Abbruch_d_Warnblinker_moeglich,attiv. ,8
IDE07007-ENG142252-Funzione di climatizzazione/riscaldamento mediante telecomando-Abbruch_Hupen_RSt,non attiv. ,8
IDE07007-ENG142255-Funzione di climatizzazione/riscaldamento mediante telecomando-Aktivierung_Drehzahlanzeige,attiv. ,8
IDE07007-ENG142254-Funzione di climatizzazione/riscaldamento mediante telecomando-Kombi_Fahrerhinweis_m_Akustik,attiv. ,8
IDE07007-ENG128461-Funzione di climatizzazione/riscaldamento mediante telecomando-Kombi_Fahrerhinweis_m_Uebernahme_RSt,attiv. ,8
IDE07007-ENG115720-Funzione di climatizzazione/riscaldamento mediante telecomando-Remote Start,non montat. ,8
IDE07007-ENG128460-Funzione di climatizzazione/riscaldamento mediante telecomando-Rueckmeldung_bei_Aktivierung,attiv. ,8
IDE07356-Posizione nel funzionamento ad intervalli,31.494474 ᄚ,2
IDE07470-ENG116719-Funzionamento protratto delle luci di posizione-Bedingungen zur Beendigung des Standlichtnachlaufs,non attiv. ,6
IDE07470-ENG116720-Funzionamento protratto delle luci di posizione-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-Funzionamento protratto delle luci di posizione-ZV verriegeln bei Klemme 15 Ein,attiv. ,6
IDE08786-ENG115723-Funzioni di illuminazione di assistenza-Assistenzfahrlicht bei Regen,attiv. ,9
IDE08786-ENG141956-Funzioni di illuminazione di assistenza-Sensore di umidit�,montat. ,9
IDE08786-ENG115724-Funzioni di illuminazione di assistenza-Lichtsensorempfindlichkeit,normale ,9
IDE08786-ENG126628-Funzioni di illuminazione di assistenza-LS_Error_Ausgabe,attiv. ,9
IDE08786-ENG142228-Funzioni di illuminazione di assistenza-Maskierung_Regenfunktion,non attiv. ,9
IDE08786-ENG141985-Funzioni di illuminazione di assistenza-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Funzioni di illuminazione di assistenza-Sensore luce solare,non montat. ,9
IDE09731-ENG154511-Luce interna 2ᆰ generazione-Ambiente_Fahrprofil_Individual,10 ,19
IDE09731-ENG154512-Luce interna 2ᆰ generazione-Ambiente_Farbliste_HMI_mit_Farbtransformation,non attiv. ,19
IDE09731-ENG154513-Luce interna 2ᆰ generazione-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,attiv. ,19
IDE09731-ENG154514-Luce interna 2ᆰ generazione-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,attiv. ,19
IDE09731-ENG125014-Luce interna 2ᆰ generazione-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Luce interna 2ᆰ generazione-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Luce interna 2ᆰ generazione-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Luce interna 2ᆰ generazione-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125018-Luce interna 2ᆰ generazione-Cockpitbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG125021-Luce interna 2ᆰ generazione-Dachbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG125028-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Fussraum,80 %,19
IDE09731-ENG125027-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Tuer,80 %,19
IDE09731-ENG115823-Luce interna 2ᆰ generazione-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125641-Luce interna 2ᆰ generazione-Farbausgabe Cockpitbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125644-Luce interna 2ᆰ generazione-Farbausgabe Dachbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125640-Luce interna 2ᆰ generazione-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125642-Luce interna 2ᆰ generazione-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125643-Luce interna 2ᆰ generazione-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125645-Luce interna 2ᆰ generazione-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125639-Luce interna 2ᆰ generazione-Farbausgabe Tuertafelbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125634-Luce interna 2ᆰ generazione-Helligkeit Cockpitbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125637-Luce interna 2ᆰ generazione-Helligkeit Dachbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125633-Luce interna 2ᆰ generazione-Helligkeit Instrumententafelbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125635-Luce interna 2ᆰ generazione-Helligkeit Lautsprecherbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125636-Luce interna 2ᆰ generazione-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG125638-Luce interna 2ᆰ generazione-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,attiv. ,19
IDE09731-ENG142233-Luce interna 2ᆰ generazione-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,non attiv. ,19
IDE09731-ENG116596-Luce interna 2ᆰ generazione-Innenlicht bei offenem Heckdeckel einschalten,attiv. ,19
IDE09731-ENG125017-Luce interna 2ᆰ generazione-Instrumententafelbeleuchtung mehrfarbig,attiv. ,19
IDE09731-ENG98648-Luce interna 2ᆰ generazione-Luce interna,Sollspannungsanforderung 13.5 ,19
IDE09731-ENG116597-Luce interna 2ᆰ generazione-KL30G ohne PWM,non attiv. ,19
IDE09731-ENG125019-Luce interna 2ᆰ generazione-Lautsprecherbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG142031-Luce interna 2ᆰ generazione-LIN-Dachkonsole mit Flaechenlicht,non montat. ,19
IDE09731-ENG125020-Luce interna 2ᆰ generazione-Mittelkonsolenbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG125023-Luce interna 2ᆰ generazione-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,non attiv. ,19
IDE09731-ENG125022-Luce interna 2ᆰ generazione-Panoramaschiebedachbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG116687-Luce interna 2ᆰ generazione-Tuerinnengriff mit Tuertafel,non montat. ,19
IDE09731-ENG116686-Luce interna 2ᆰ generazione-Tuerinnengriffbeleuchtung mit I-Tafel,non montat. ,19
IDE09731-ENG125016-Luce interna 2ᆰ generazione-Tuertafelbeleuchtung mehrfarbig,non attiv. ,19
IDE09731-ENG142184-Luce interna 2ᆰ generazione-Weckfaehigkeit_klemme_30G,montat. ,19
IDE09731-ENG125015-Luce interna 2ᆰ generazione-weicher Farbwechsel,non attiv. ,19
IDE09732-ENG154509-Luce interna: configurazione delle luci-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Luce interna: configurazione delle luci-Ambient_Farbliste_HMI,attiv. ,5
IDE09732-ENG115870-Luce interna: configurazione delle luci-Ambiente_Applikationsleisten_in_Instrumententafel,montat. ,5
IDE09732-ENG115871-Luce interna: configurazione delle luci-Ambiente_Applikationsleisten_in_Tuertafel,montat. ,5
IDE09732-ENG115872-Luce interna: configurazione delle luci-Ambiente_Lautsprecher,non montat. ,5
IDE09732-ENG126836-Luce interna: configurazione delle luci-Ambientemenue mit alle Zonen,attiv. ,5
IDE09732-ENG126835-Luce interna: configurazione delle luci-Ambientemenue mit globalem aus,attiv. ,5
IDE09732-ENG125646-Luce interna: configurazione delle luci-Cockpitbeleuchtung,non montat. ,5
IDE09732-ENG125648-Luce interna: configurazione delle luci-Dachbeleuchtung,montat. ,5
IDE09732-ENG125651-Luce interna: configurazione delle luci-Farbwahl ueber Fahrprofil,non montat. ,5
IDE09732-ENG125650-Luce interna: configurazione delle luci-Farbwahl ueber HMI,non montat. ,5
IDE09732-ENG114629-Luce interna: configurazione delle luci-Illuminazione vano piedi,montat. ,5
IDE09732-ENG133385-Luce interna: configurazione delle luci-Frei_Farbwahl_ueber_HMI,non attiv. ,5
IDE09732-ENG126834-Luce interna: configurazione delle luci-LIN-Dachkonsole lokal aktivierbar,non attiv. ,5
IDE09732-ENG125647-Luce interna: configurazione delle luci-Mittelkonsolenbeleuchtung,montat. ,5
IDE09732-ENG125649-Luce interna: configurazione delle luci-Panoramaschiebedachbeleuchtung,montat. ,5
IDE09761-ENG126617-Linea caratteristica ventilatore sedile-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Linea caratteristica ventilatore sedile-Level_1_Sitz,25 %,17
IDE09761-ENG126619-Linea caratteristica ventilatore sedile-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Linea caratteristica ventilatore sedile-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Linea caratteristica ventilatore sedile-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Linea caratteristica ventilatore sedile-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Linea caratteristica ventilatore sedile-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Linea caratteristica ventilatore sedile-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Linea caratteristica ventilatore sedile-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Linea caratteristica ventilatore sedile-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Linea caratteristica ventilatore sedile-Level_6_Lehne,85 %,17
IDE09761-ENG126626-Linea caratteristica ventilatore sedile-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Linea caratteristica ventilatore sedile-Sitzlueftung,non montat. ,17
IDE09761-ENG142183-Linea caratteristica ventilatore sedile-Sitzlueftung_reduzierbar,non montat. ,17
IDE09761-ENG142025-Linea caratteristica ventilatore sedile-Sitzpneumatik,non montat. ,17
IDE10298-Posizione di parcheggio alternata 1,7.494498 ᄚ,2
IDE10299-Posizione di parcheggio alternata 2,29.494476 ᄚ,2
IDE11477-ENG128587-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_fussraum,0.67 ,256
IDE11477-ENG128571-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_miko,0.67 ,256
IDE11477-ENG128635-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Parametri illuminazione abitacolo-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Parametri illuminazione abitacolo-p_ambientelicht_verbauinformation_HMI,11111111  ,256
IDE11477-ENG128660-Parametri illuminazione abitacolo-p_ambientelicht_verbauinformation_HMI_2,11111111  ,256
IDE11477-ENG128661-Parametri illuminazione abitacolo-p_ambientelicht_verbauinformation_HMI_3,11111111  ,256
IDE11477-ENG128662-Parametri illuminazione abitacolo-p_ambientelicht_verbauinformation_HMI_4,0 ,256
IDE11477-ENG128655-Parametri illuminazione abitacolo-p_ambienteumfang_mehrfarbig_HMI,00000101  ,256
IDE11477-ENG128656-Parametri illuminazione abitacolo-p_ambienteumfang_mehrfarbig_HMI_2,11111111  ,256
IDE11477-ENG128657-Parametri illuminazione abitacolo-p_ambienteumfang_mehrfarbig_HMI_3,11111111  ,256
IDE11477-ENG128658-Parametri illuminazione abitacolo-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128652-Parametri illuminazione abitacolo-p_dimmfaktor_farbwechsel_ab,1 ,256
IDE11477-ENG128651-Parametri illuminazione abitacolo-p_dimmfaktor_farbwechsel_auf,1 ,256
IDE11477-ENG128654-Parametri illuminazione abitacolo-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128653-Parametri illuminazione abitacolo-p_farbwechsel_delay,0 ,256
IDE11477-ENG128596-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128516-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128580-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128593-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128513-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128577-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_miko,126 %,256
IDE11477-ENG128641-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Parametri illuminazione abitacolo-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128595-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128515-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128579-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128592-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128512-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128576-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Parametri illuminazione abitacolo-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128597-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_fussraum,100 %,256
IDE11477-ENG128517-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_innenlicht,100 %,256
IDE11477-ENG128581-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Parametri illuminazione abitacolo-p_helligkeit_einausstieg_tueren,100 %,256
IDE11477-ENG128588-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128508-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_innenlicht,100 %,256
IDE11477-ENG128572-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Parametri illuminazione abitacolo-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128602-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128522-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128598-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128518-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
IDE11477-ENG128594-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128514-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %,256
IDE11477-ENG128578-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Parametri illuminazione abitacolo-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128511-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_miko,127 %,256
IDE11477-ENG128639-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
IDE11477-ENG128590-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128510-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_miko,126 %,256
IDE11477-ENG128638-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Parametri illuminazione abitacolo-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Parametri illuminazione abitacolo-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Parametri illuminazione abitacolo-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Parametri illuminazione abitacolo-p_helligkeit_max_fussraum,100 %,256
IDE11477-ENG128509-Parametri illuminazione abitacolo-p_helligkeit_max_innenlicht,100 %,256
IDE11477-ENG128573-Parametri illuminazione abitacolo-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Parametri illuminazione abitacolo-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Parametri illuminazione abitacolo-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Parametri illuminazione abitacolo-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Parametri illuminazione abitacolo-p_helligkeit_max_tueren,100 %,256
IDE11477-ENG128599-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128519-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128600-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128520-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128601-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128521-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Parametri illuminazione abitacolo-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG137165-Parametri illuminazione abitacolo-p_t_HMI_verzoegerung_helligkeitswerte,100 ms,256
IDE11477-ENG128488-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_cockpit,0.0 s,256
IDE11477-ENG128502-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_dach,0.0 s,256
IDE11477-ENG128481-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_fussraum,0.0 s,256
IDE11477-ENG128467-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_innenlicht,0.0 s,256
IDE11477-ENG128495-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_miko,0.0 s,256
IDE11477-ENG128474-Parametri illuminazione abitacolo-p_t_verzoegerung_ausstieg_tueren,0.0 s,256
IDE11477-ENG128487-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_cockpit,0.0 s,256
IDE11477-ENG128501-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_dach,0.0 s,256
IDE11477-ENG128480-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128466-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_innenlicht,0.0 s,256
IDE11477-ENG128494-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_miko,0.0 s,256
IDE11477-ENG128473-Parametri illuminazione abitacolo-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11477-ENG128490-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_cockpit,0.0 s,256
IDE11477-ENG128504-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_dach,0.0 s,256
IDE11477-ENG128483-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_fussraum,0.0 s,256
IDE11477-ENG128469-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_innenlicht,0.0 s,256
IDE11477-ENG128497-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_miko,0.0 s,256
IDE11477-ENG128476-Parametri illuminazione abitacolo-p_t_verzoegerung_entriegelt_tueren,0.0 s,256
IDE11477-ENG128489-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_cockpit,0.0 s,256
IDE11477-ENG128503-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_dach,0.0 s,256
IDE11477-ENG128482-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_fussraum,0.0 s,256
IDE11477-ENG128468-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_innenlicht,0.0 s,256
IDE11477-ENG128496-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_miko,0.0 s,256
IDE11477-ENG128475-Parametri illuminazione abitacolo-p_t_verzoegerung_oeffnen_tueren,0.0 s,256
IDE11477-ENG128491-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_cockpit,0.0 s,256
IDE11477-ENG128505-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_dach,0.0 s,256
IDE11477-ENG128484-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_fussraum,0.0 s,256
IDE11477-ENG128470-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_innenlicht,0.0 s,256
IDE11477-ENG128498-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_miko,0.0 s,256
IDE11477-ENG128477-Parametri illuminazione abitacolo-p_t_verzoegerung_schliessen_tueren,0.0 s,256
IDE11477-ENG128492-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_cockpit,0.0 s,256
IDE11477-ENG128506-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_dach,0.0 s,256
IDE11477-ENG128485-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_fussraum,0.0 s,256
IDE11477-ENG128471-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_innenlicht,0.0 s,256
IDE11477-ENG128499-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_miko,0.0 s,256
IDE11477-ENG128478-Parametri illuminazione abitacolo-p_t_verzoegerung_schluessel_ab_tueren,0.0 s,256
IDE11477-ENG128493-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_cockpit,0.0 s,256
IDE11477-ENG128507-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_dach,0.0 s,256
IDE11477-ENG128486-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_fussraum,0.0 s,256
IDE11477-ENG128472-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_innenlicht,0.0 s,256
IDE11477-ENG128500-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_miko,0.0 s,256
IDE11477-ENG128479-Parametri illuminazione abitacolo-p_t_verzoegerung_verriegelt_tueren,0.0 s,256
IDE11477-ENG128663-Parametri illuminazione abitacolo-p_verzoegerung_berechnen,0 ,256
IDE11714-ENG126827-Luce soffusa: lista colori-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Luce soffusa: lista colori-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Luce soffusa: lista colori-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Luce soffusa: lista colori-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Luce soffusa: lista colori-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Luce soffusa: lista colori-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Luce soffusa: lista colori-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Luce soffusa: lista colori-Blauwert Farbe 7,32 ,30
IDE11714-ENG133426-Luce soffusa: lista colori-Blauwert Farbe 8,10 ,30
IDE11714-ENG133429-Luce soffusa: lista colori-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Luce soffusa: lista colori-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Luce soffusa: lista colori-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Luce soffusa: lista colori-Gruenwert Farbe 2,61 ,30
IDE11714-ENG126832-Luce soffusa: lista colori-Gruenwert Farbe 3,64 ,30
IDE11714-ENG133413-Luce soffusa: lista colori-Gruenwert Farbe 4,128 ,30
IDE11714-ENG133416-Luce soffusa: lista colori-Gruenwert Farbe 5,191 ,30
IDE11714-ENG133419-Luce soffusa: lista colori-Gruenwert Farbe 6,255 ,30
IDE11714-ENG133422-Luce soffusa: lista colori-Gruenwert Farbe 7,165 ,30
IDE11714-ENG133425-Luce soffusa: lista colori-Gruenwert Farbe 8,241 ,30
IDE11714-ENG133428-Luce soffusa: lista colori-Gruenwert Farbe 9,255 ,30
IDE11714-ENG126825-Luce soffusa: lista colori-Rotwert Farbe 1,121 ,30
IDE11714-ENG133430-Luce soffusa: lista colori-Rotwert Farbe 10,128 ,30
IDE11714-ENG126828-Luce soffusa: lista colori-Rotwert Farbe 2,121 ,30
IDE11714-ENG126831-Luce soffusa: lista colori-Rotwert Farbe 3,255 ,30
IDE11714-ENG133412-Luce soffusa: lista colori-Rotwert Farbe 4,255 ,30
IDE11714-ENG133415-Luce soffusa: lista colori-Rotwert Farbe 5,255 ,30
IDE11714-ENG133418-Luce soffusa: lista colori-Rotwert Farbe 6,255 ,30
IDE11714-ENG133421-Luce soffusa: lista colori-Rotwert Farbe 7,218 ,30
IDE11714-ENG133424-Luce soffusa: lista colori-Rotwert Farbe 8,166 ,30
IDE11714-ENG133427-Luce soffusa: lista colori-Rotwert Farbe 9,191 ,30
IDE11944-ENG142014-Autorizzazione all'accesso e messa in moto senza chiave-Elektische_Lenkradverriegelung,non montat. ,3
IDE11944-ENG141948-Autorizzazione all'accesso e messa in moto senza chiave-Kessy,non montat. ,3
IDE11944-ENG116653-Autorizzazione all'accesso e messa in moto senza chiave-Kessy Komfort oeffnen,non attiv. ,3
IDE11944-ENG116654-Autorizzazione all'accesso e messa in moto senza chiave-Kessy Komfort schliessen,attiv. ,3
IDE11944-ENG116655-Autorizzazione all'accesso e messa in moto senza chiave-Kessy Komfortbedienung Reichweitenbegrenzung,non attiv. ,3
IDE11944-ENG116626-Autorizzazione all'accesso e messa in moto senza chiave-Oeffnung Heckdeckel bei Wiederentriegelung,non attiv. ,3
IDE12412-ENG154526-Luci soffusi: lista colori LIN-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154527-Luci soffusi: lista colori LIN-Blauwert_Farbe_10_lin,0 ,30
IDE12412-ENG154537-Luci soffusi: lista colori LIN-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-Luci soffusi: lista colori LIN-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-Luci soffusi: lista colori LIN-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-Luci soffusi: lista colori LIN-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-Luci soffusi: lista colori LIN-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-Luci soffusi: lista colori LIN-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-Luci soffusi: lista colori LIN-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-Luci soffusi: lista colori LIN-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-Luci soffusi: lista colori LIN-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-Luci soffusi: lista colori LIN-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-Luci soffusi: lista colori LIN-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-Luci soffusi: lista colori LIN-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-Luci soffusi: lista colori LIN-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-Luci soffusi: lista colori LIN-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-Luci soffusi: lista colori LIN-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-Luci soffusi: lista colori LIN-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-Luci soffusi: lista colori LIN-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-Luci soffusi: lista colori LIN-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-Luci soffusi: lista colori LIN-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-Luci soffusi: lista colori LIN-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-Luci soffusi: lista colori LIN-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-Luci soffusi: lista colori LIN-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-Luci soffusi: lista colori LIN-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-Luci soffusi: lista colori LIN-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-Luci soffusi: lista colori LIN-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-Luci soffusi: lista colori LIN-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-Luci soffusi: lista colori LIN-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-Luci soffusi: lista colori LIN-Rotwert_Farbe_9_lin,0 ,30
MAS01490-ENG142027-Gestione energia-Energiemanagement Abschaltung,attiv. ,5
MAS01490-ENG116830-Gestione energia-Energy_Management_Adaptation,Gestione energia attiva ,5
MAS01490-ENG142256-Gestione energia-Hochvoltfahrzeug,non montat. ,5
MAS01490-ENG141950-Gestione energia-Veicolo ibrido,no ,5
MAS01490-ENG133400-Gestione energia-Praediktives_Energiemanagement,non attiv. ,5
MAS01490-ENG141978-Gestione energia-Recuperation,attiv. ,5
MAS01490-ENG142037-Gestione energia-Zweitbatterie,non montat. ,5
MAS05055-punto di inversione inferiore,31.494474 ᄚ,2
MAS05056-punto di inversione superiore,170.494336 ᄚ,2
MAS08228-ENG133434-Sensore luce-Daemmerungsgrenze: Hysterese_obergrenze,1200 lx,24
MAS08228-ENG133435-Sensore luce-Daemmerungsgrenze_Hysterese_untergrenze,2200 lx,24
MAS08228-ENG133444-Sensore luce-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133433-Sensore luce-Einschaltgrenze_CHO_LHO,600 lx,24
MAS08228-ENG133437-Sensore luce-Helligkeitsgrenze_Licht__einschalten,1200 lx,24
MAS08228-ENG133438-Sensore luce-Helligkeitsgrenze_Licht_ausschalten,2200 lx,24
MAS08228-ENG133445-Sensore luce-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Sensore luce-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG142230-Sensore luce-HMI_Exterior_light_on_highway,non attiv. ,24
MAS08228-ENG142231-Sensore luce-HMI_Exterior_light_on_rain,non attiv. ,24
MAS08228-ENG142232-Sensore luce-HMI_exterior_light_sensitivity,frueh ,24
MAS08228-ENG142229-Sensore luce-HMI_Wiper_Comfort_Rain_Sensor_OFF,not active ,24
MAS08228-ENG126628-Sensore luce-LS_Error_Ausgabe,non attiv. ,24
MAS08228-ENG133442-Sensore luce-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Sensore luce-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Sensore luce-Minimale_Ausgangsspannung,0 mV,24
MAS08228-ENG133439-Sensore luce-Minimale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133443-Sensore luce-Tunnel_einschalt_verzoegerung,02 ,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,non attiv. ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,attiv. ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,attiv. ,4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler,non montat. ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,64 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,128 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,191 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,255 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,255 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,255 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,255 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,255 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,255 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,255 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,255 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,255 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,191 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,128 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,64 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,255 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,159 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,255 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,255 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,255 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,255 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,255 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,255 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,191 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,128 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,64 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,255 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,159 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,64 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,64 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,128 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,191 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,255 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,255 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,255 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,255 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,255 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,255 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,159 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.20 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.20 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.20 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,Porta ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,Porta ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,Vano piedi ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,Porta ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,Porta ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,Vano piedi ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,Porta ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,console centrale ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,Porta ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,Porta ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,Porta ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,Porta ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,Porta ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,Porta ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,Porta ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,Pi� colori ,30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,non montat. ,30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,Un colore ,30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,non montat. ,30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,non montat. ,30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,NOT-DEFINED ,30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,non montat. ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,Pi� colori ,30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,Pi� colori ,30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,Pi� colori ,30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,Pi� colori ,30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,non montat. ,30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,non montat. ,30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,non montat. ,30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,non montat. ,30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0 ,60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,10 ,60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0 ,60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0 ,60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0 ,60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0 ,60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0 ,60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0 ,60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0 ,60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,7 ,60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,8 ,60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,9 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0 ,60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0 ,60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0 ,60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0 ,60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0 ,60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0 ,60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0 ,60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0 ,60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0 ,60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0 ,60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0 ,60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0 ,60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,montat. ,60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,non montat. ,60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,non montat. ,60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,non montat. ,60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,non montat. ,60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,non montat. ,60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,non montat. ,60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,non montat. ,60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,non montat. ,60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,non montat. ,60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,non montat. ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,montat. ,60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,non montat. ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,montat. ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,montat. ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,non montat. ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,montat. ,60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,non montat. ,60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,non montat. ,60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,non montat. ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,3 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,8 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,20 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,21 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,22 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,23 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,24 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,7 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,4 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,6 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,9 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,8 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,5 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,18 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Au�enlicht_Blinker-ABBA_Blinken,non attiv. ,10
ENG141649-ENG133379-Au�enlicht_Blinker-Abbruch Komfortblinken,attiv. ,10
ENG141649-ENG116590-Au�enlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte ,10
ENG141649-ENG121966-Au�enlicht_Blinker-Lampeggio impatto,non attiv. ,10
ENG141649-ENG122207-Au�enlicht_Blinker-DWA_Alarm_Blinken,attiv. ,10
ENG141649-ENG122206-Au�enlicht_Blinker-DWA_Schaerfungsquittung,attiv. ,10
ENG141649-ENG142194-Au�enlicht_Blinker-dynamisch_blinken_10,attiv. ,10
ENG141649-ENG142195-Au�enlicht_Blinker-Dynamische_Blink_Delay,50 ms,10
ENG141649-ENG126819-Au�enlicht_Blinker-Emergency_alert_blinken,non attiv. ,10
ENG141649-ENG154601-Au�enlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG115774-Au�enlicht_Blinker-Frecce comfort,attiv. ,10
ENG141649-ENG116587-Au�enlicht_Blinker-Komfortblinken Blinkzyklen,3 ,10
ENG141649-ENG122208-Au�enlicht_Blinker-Multi_kollisions_Blinken,non attiv. ,10
ENG141649-ENG122209-Au�enlicht_Blinker-Notwarn_blinken_NBA_Phase_2,non attiv. ,10
ENG141649-ENG121967-Au�enlicht_Blinker-Lampeggio antipanico,attiv. ,10
ENG141649-ENG154711-Au�enlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Au�enlicht_Blinker-Richtungs_blinken_links,attiv. ,10
ENG141649-ENG122210-Au�enlicht_Blinker-Richtungs_blinken_rechts,attiv. ,10
ENG141649-ENG122201-Au�enlicht_Blinker-Schluessel_Anlern_Blinken,attiv. ,10
ENG141649-ENG121968-Au�enlicht_Blinker-Lampeggio allarme taxi,attiv. ,10
ENG141649-ENG126629-Au�enlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,attiv. ,10
ENG141649-ENG122202-Au�enlicht_Blinker-UGDO_ Anlern_Blinken,attiv. ,10
ENG141649-ENG142029-Au�enlicht_Blinker-Warnblinken_durch_Fahrerassistenz,attiv. ,10
ENG141649-ENG122214-Au�enlicht_Blinker-Warnblinken_Zuendung_AUS,attiv. ,10
ENG141649-ENG122213-Au�enlicht_Blinker-Warnblinken_Zuendung_EIN,attiv. ,10
ENG141649-ENG122204-Au�enlicht_Blinker-ZV_Blinken_auf,attiv. ,10
ENG141649-ENG122203-Au�enlicht_Blinker-ZV_Blinken_zu,attiv. ,10
ENG141647-ENG141986-Au�enlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Au�enlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Au�enlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG115833-Au�enlicht_Front-Fahrlicht bei Tag,Luci diurne ,9
ENG141647-ENG142193-Au�enlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Au�enlicht_Front-Lichthupe bei Zuendung aus moeglich,attiv. ,9
ENG141647-ENG115832-Au�enlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,non attiv. ,9
ENG141647-ENG142191-Au�enlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,non attiv. ,9
ENG141647-ENG142190-Au�enlicht_Front-Signaturlicht_verbaut,non montat. ,9
ENG141647-ENG116592-Au�enlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,attiv. ,9
ENG141647-ENG116594-Au�enlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,non attiv. ,9
ENG141647-ENG122184-Au�enlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,non attiv. ,9
ENG141647-ENG115734-Au�enlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,non attiv. ,9
ENG141647-ENG116593-Au�enlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,non attiv. ,9
ENG141647-ENG115733-Au�enlicht_Front-Tagfahrlichtkontrollleuchte,non attiv. ,9
ENG141647-ENG142192-Au�enlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,non attiv. ,9
ENG141647-ENG116591-Au�enlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,attiv. ,9
ENG141647-ENG115860-Au�enlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,no ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,attiv. ,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,non attiv. ,5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe,non montat. ,5
ENG141656-ENG142020-Au�enlicht_uebergreifend-Luci standard,non montat. ,18
ENG141656-ENG133381-Au�enlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar �ber Energiemanagement ,18
ENG141656-ENG133380-Au�enlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar �ber Energiemanagement ,18
ENG141656-ENG142188-Au�enlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung ,18
ENG141656-ENG115656-Au�enlicht_uebergreifend-Coming Home Leuchten,Luci anabbaglianti ,18
ENG141656-ENG116601-Au�enlicht_uebergreifend-Coming Home Verbaustatus,manualmente ,18
ENG141656-ENG116604-Au�enlicht_uebergreifend-Coming-home Einschaltereignis,Driver door ,18
ENG141656-ENG130581-Au�enlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,attiv. ,18
ENG141656-ENG126818-Au�enlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
ENG141656-ENG137034-Au�enlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Au�enlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,18
ENG141656-ENG154177-Au�enlicht_uebergreifend-Fendinebbia,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Au�enlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Au�enlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG142189-Au�enlicht_uebergreifend-HVLM_Ladezustandsanzeige,no ,18
ENG141656-ENG115858-Au�enlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Au�enlicht_uebergreifend-LCM_blinker,falso ,18
ENG141656-ENG141992-Au�enlicht_uebergreifend-LDS_mit_AFL,si ,18
ENG141656-ENG141991-Au�enlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,si ,18
ENG141656-ENG141990-Au�enlicht_uebergreifend-LDS_mit_Nebellicht,si ,18
ENG141656-ENG141993-Au�enlicht_uebergreifend-LDS_mit_Standlichtstellung,si ,18
ENG141656-ENG115657-Au�enlicht_uebergreifend-Leaving-Home Verbausstatus,liberat. ,18
ENG141656-ENG141989-Au�enlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG115862-Au�enlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,18
ENG141656-ENG142034-Au�enlicht_uebergreifend-Light_Control_Module,montat. ,18
ENG141656-ENG98354-Au�enlicht_uebergreifend-Luci anabbaglianti,Keine_Spannungsanforderung ,18
ENG141656-ENG115863-Au�enlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Au�enlicht_uebergreifend-Menueeinstellung Cominghome,10 secondi ,18
ENG141656-ENG116607-Au�enlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 secondi ,18
ENG141656-ENG116602-Au�enlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,attiv. ,18
ENG141656-ENG116606-Au�enlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,attiv. ,18
ENG141656-ENG115859-Au�enlicht_uebergreifend-Parklicht ueber LSS aktiviert,Unilaterale ,18
ENG141656-ENG126816-Au�enlicht_uebergreifend-Standlicht aus,attiv. ,18
ENG141656-ENG115829-Au�enlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,attiv. ,18
ENG141656-ENG133383-Au�enlicht_uebergreifend-Standlicht-Verf�gbarkeit,24 s,18
ENG141656-ENG154174-Au�enlicht_uebergreifend-Indicatori di direzione,Keine_Spannungsanforderung ,18
ENG141656-ENG126817-Au�enlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,non attiv. ,18
ENG126647-ENG98399-debug_light_function-Attivazione,0 ,11
ENG126647-ENG101417-debug_light_function-Adresse,0 ,11
ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11
ENG126647-ENG126821-debug_light_function-Divisor,0 ,11
ENG126647-ENG98827-debug_light_function-Offset,0 ,11
ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0,0.0 %,6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1,50.0 %,6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2,100.0 %,6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0,0.0 %,6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1,50.0 %,6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2,100.0 %,6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-MAS13782-Fernlicht_assistent-Fari ad accensione automat.: sensibilit� regolabile tramite BAP,disponibile ,6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,attiv. ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,disponibile ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,disponibile ,6
ENG141685-Front_wash_function,10 ,2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,attiv. ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm,attiv. ,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,attiv. ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,non attiv. ,6
ENG141682-ENG141966-Front_wiper-Frontwischertyp,LIN ,6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,attiv. ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,non attiv. ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Disattivazione ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz,attiv. ,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,non attiv. ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,non attiv. ,6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,non attiv. ,6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube,non attiv. ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,non attiv. ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,attiv. ,6
ENG99457-ENG117394-Riscaldamento della zona testa-blower_speed,0 ,2
ENG99457-ENG98971-Riscaldamento della zona testa-Temperature,-3 ,2
ENG141645-MAS00211-HW_Verbau-Mancanza liquido freni,montat. ,8
ENG141645-MAS00212-HW_Verbau-Mancanza acqua di lavaggio,montat. ,8
ENG141645-MAS00213-HW_Verbau-Mancanza liquido di raffreddamento,montat. ,8
ENG141645-MAS00214-HW_Verbau-Usura pastiglie freni,montat. ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,non montat. ,8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,non attiv. ,8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,non montat. ,8
ENG141645-ENG141952-HW_Verbau-Sensore della temperatura esterna,montat. ,8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube,montat. ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,non montat. ,8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer,non montat. ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,attiv. ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,non attiv. ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0 ,16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,non attiv. ,16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,non attiv. ,16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,non attiv. ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,non attiv. ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,non attiv. ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,non attiv. ,16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,non attiv. ,16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,non attiv. ,16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,non attiv. ,16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15,maximize ,16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15,maximize ,16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15,maximize ,16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15,100 ,16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15,0 ,16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15,0 ,16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15,0 ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15,Always ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,SCONOSCIUTO (76),16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15,non attiv. ,16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15,non attiv. ,16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15,non attiv. ,16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15,non attiv. ,16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15,non attiv. ,16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15,non attiv. ,16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15,non attiv. ,16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0 ,16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0 ,16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,non attiv. ,16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,non attiv. ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,non attiv. ,16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,non attiv. ,16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,non attiv. ,16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,non attiv. ,16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,non attiv. ,16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,non attiv. ,16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,non attiv. ,16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0 ,16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0 ,16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0 ,16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,non attiv. ,16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,non attiv. ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,non attiv. ,16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,non attiv. ,16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,non attiv. ,16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,non attiv. ,16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,non attiv. ,16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,non attiv. ,16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,non attiv. ,16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0 ,16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0 ,16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,non attiv. ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,non attiv. ,16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,non attiv. ,16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,non attiv. ,16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,non attiv. ,16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,non attiv. ,16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,non attiv. ,16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0 ,16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0 ,16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,non attiv. ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,non attiv. ,16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,non attiv. ,16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,non attiv. ,16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,non attiv. ,16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,non attiv. ,16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,non attiv. ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0 ,16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0 ,16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,non attiv. ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,non attiv. ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,non attiv. ,16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,non attiv. ,16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,non attiv. ,16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,non attiv. ,16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,non attiv. ,16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0 ,16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0 ,16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,non attiv. ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,non attiv. ,16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,non attiv. ,16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,non attiv. ,16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,non attiv. ,16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,non attiv. ,16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,non attiv. ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,non attiv. ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,non attiv. ,16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,non attiv. ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,non attiv. ,16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,non attiv. ,16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,non attiv. ,16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,non attiv. ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,non attiv. ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,non attiv. ,16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,non attiv. ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,non attiv. ,16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,non attiv. ,16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,non attiv. ,16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,non attiv. ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,non attiv. ,16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,non attiv. ,16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,non attiv. ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,non attiv. ,16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,non attiv. ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,non attiv. ,16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,non attiv. ,16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,non attiv. ,16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,non attiv. ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Luci dei freni ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,non attiv. ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,non attiv. ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,non attiv. ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,non attiv. ,16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,non attiv. ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,non attiv. ,16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,non attiv. ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Luci dei freni ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,non attiv. ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,non attiv. ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,non attiv. ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,non attiv. ,16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,non attiv. ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,non attiv. ,16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,non attiv. ,16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0 ,16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Luci dei freni ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,non attiv. ,16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,non attiv. ,16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,non attiv. ,16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,non attiv. ,16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,non attiv. ,16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,non attiv. ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,non attiv. ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,non attiv. ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,non attiv. ,16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,non attiv. ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,non attiv. ,16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,non attiv. ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Luci di parcheggio des. ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,non attiv. ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,non attiv. ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,non attiv. ,16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,non attiv. ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,non attiv. ,16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,non attiv. ,16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0 ,16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0 ,16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0 ,16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28 ,16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,non attiv. ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,non attiv. ,16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,non attiv. ,16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,non attiv. ,16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,non attiv. ,16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,non attiv. ,16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,non attiv. ,16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,non attiv. ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,non attiv. ,16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,non attiv. ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,non attiv. ,16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,non attiv. ,16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,non attiv. ,16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,non attiv. ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,36 - LED Kleinleistung ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,non attiv. ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,non attiv. ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,non attiv. ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,non attiv. ,16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,non attiv. ,16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,non attiv. ,16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,non attiv. ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0 ,16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0 ,16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht ,16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,non attiv. ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,non attiv. ,16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,non attiv. ,16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,non attiv. ,16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,non attiv. ,16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,non attiv. ,16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0 ,16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0 ,16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0 ,16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,non attiv. ,16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,non attiv. ,16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,non attiv. ,16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,non attiv. ,16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,non attiv. ,16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,non attiv. ,16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,non attiv. ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,non attiv. ,16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,non attiv. ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,non attiv. ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,non attiv. ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,non attiv. ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,non attiv. ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,non attiv. ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,non attiv. ,16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,non attiv. ,16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0 ,16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0 ,16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Luce vano piedi ,16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,non attiv. ,16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,non attiv. ,16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,non attiv. ,16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,non attiv. ,16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,non attiv. ,16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,non attiv. ,16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,non attiv. ,16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0 ,16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0 ,16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00 ,16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,non attiv. ,16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,non attiv. ,16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,non attiv. ,16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,non attiv. ,16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,non attiv. ,16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,non attiv. ,16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,non attiv. ,16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,non attiv. ,16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,non attiv. ,16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0 ,16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0 ,16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00 ,16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,non attiv. ,16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,non attiv. ,16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,non attiv. ,16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,non attiv. ,16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,non attiv. ,16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,non attiv. ,16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,non attiv. ,16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,non attiv. ,16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,non attiv. ,16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0 ,16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0 ,16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00 ,16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,non attiv. ,16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,non attiv. ,16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,non attiv. ,16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,non attiv. ,16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,non attiv. ,16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,non attiv. ,16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,non attiv. ,16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,non attiv. ,16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,non attiv. ,16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0 ,16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0 ,16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00 ,16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,non attiv. ,16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,non attiv. ,16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,non attiv. ,16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,non attiv. ,16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,non attiv. ,16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,non attiv. ,16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,non attiv. ,16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,non attiv. ,16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,non attiv. ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,non attiv. ,16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,non attiv. ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,non attiv. ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,non attiv. ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,non attiv. ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,non attiv. ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,non attiv. ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,non attiv. ,16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,non attiv. ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,non attiv. ,16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,non attiv. ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,non attiv. ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,non attiv. ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,non attiv. ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,non attiv. ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,non attiv. ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,non attiv. ,16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,non attiv. ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,non attiv. ,16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,non attiv. ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,non attiv. ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,non attiv. ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,non attiv. ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,non attiv. ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,non attiv. ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,non attiv. ,16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,non attiv. ,16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0 ,16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0 ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,non attiv. ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,non attiv. ,16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,non attiv. ,16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,non attiv. ,16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,non attiv. ,16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,non attiv. ,16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0 ,16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0 ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,non attiv. ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,non attiv. ,16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,non attiv. ,16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,non attiv. ,16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,non attiv. ,16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,non attiv. ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0 ,16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,non attiv. ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Luci di parcheggio des. ,16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,non attiv. ,16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,non attiv. ,16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,non attiv. ,16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,non attiv. ,16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0 ,16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,non attiv. ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,non attiv. ,16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,non attiv. ,16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,non attiv. ,16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,non attiv. ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 1B 00 80 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,26 00 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR,1-Sensor_LWR ,62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,non attiv. ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz,15 %,62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe,10.0 s,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normale ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,negativ. ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,95.0 %,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr,100 Hz,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,attiv. ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,non attiv. ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,non montat. ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG126648-MAS10452-LIN-Mirrormode-Bus dati LIN 1,non attiv. ,1
ENG126648-MAS10453-LIN-Mirrormode-Bus dati LIN 2,non attiv. ,1
ENG126648-MAS10454-LIN-Mirrormode-Bus dati LIN 3,non attiv. ,1
ENG126648-MAS12782-LIN-Mirrormode-Bus dati LIN 4,non attiv. ,1
ENG126648-MAS12783-LIN-Mirrormode-Bus dati LIN 5,non attiv. ,1
ENG126648-MAS12784-LIN-Mirrormode-Bus dati LIN 6,non attiv. ,1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,non attiv. ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.0 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Vernetzung-Elettronica climatizzatore,montat. ,8
ENG122979-ENG141968-Vernetzung-Anhaengeranschlussgeraet,non montat. ,8
ENG122979-ENG141974-Vernetzung-Bremsen_Steuergeraet,montat. ,8
ENG122979-ENG141953-Vernetzung-Getriebesteuergeraet,montat. ,8
ENG122979-ENG99457-Vernetzung-Riscaldamento della zona testa,non montat. ,8
ENG122979-ENG142040-Vernetzung-Kunden_spezifisches_Funktions_SG,non montat. ,8
ENG122979-ENG141969-Vernetzung-UGDO,non montat. ,8
ENG124714-ENG142044-OCU-DWA_push,attiv. ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,attiv. ,8
ENG124714-OCU-,non montat. ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
ENG98831-ENG126849-Personalizzazione-Aktivierungsoption_im_HMI-Menue_sichtbar,attiv. ,16
ENG98831-ENG133401-Personalizzazione-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG133402-Personalizzazione-Automatische_ Schluesselzuordnung,non attiv. ,16
ENG98831-ENG126850-Personalizzazione-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,attiv. ,16
ENG98831-ENG126848-Personalizzazione-Personalisierung_aktiv,attiv. ,16
ENG98831-ENG141994-Personalizzazione-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalizzazione-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,attiv. ,16
ENG98831-ENG142030-Personalizzazione-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalizzazione-PSO_FSG_Setup2_Bit_1,attiv. ,16
ENG98831-ENG133405-Personalizzazione-PSO_FSG_Setup2_Bit_2,attiv. ,16
ENG98831-ENG133406-Personalizzazione-PSO_FSG_Setup2_Bit_3,non attiv. ,16
ENG98831-ENG133407-Personalizzazione-PSO_FSG_Setup2_Bit_4,non attiv. ,16
ENG141646-MAS01065-Querschnitts_funktionen-Marca,VW ,5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,attiv. ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,non attiv. ,5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,non attiv. ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,attiv. ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,attiv. ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,non attiv. ,5
ENG141646-ENG141964-Querschnitts_funktionen-Posizione dello sterzo,sinistra ,5
ENG141646-ENG141965-Querschnitts_funktionen-Lato traffico,destra ,5
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Impianto lavafari,montat. ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,attiv. ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,400 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,400 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG141684-SFT271873-Slave_systems_identification-Centralina del servomotore del tergicristallo,indisponibile ,6
ENG141684-SFT271874-Slave_systems_identification-Sensore pioggia e luminosit�,indisponibile ,6
ENG141684-SFT271875-Slave_systems_identification-Interruttore delle luci,indisponibile ,6
ENG141684-SFT271876-Slave_systems_identification-Centralina dell'aprigarage,indisponibile ,6
ENG141684-SFT271877-Slave_systems_identification-Unit� comandi dell'aprigarage,indisponibile ,6
ENG141684-SFT271894-Slave_systems_identification-Sensore dell'impianto antifurto,indisponibile ,6
ENG141684-SFT271896-Slave_systems_identification-Avv. acustico,indisponibile ,6
ENG141684-SFT271904-Slave_systems_identification-Centralina del tettuccio scorrevole,indisponibile ,6
ENG141684-SFT271910-Slave_systems_identification-Centralina dell'elettronica del tetto,indisponibile ,6
ENG141684-SFT271928-Slave_systems_identification-Centralina della tendina del tetto,indisponibile ,6
ENG141684-SFT271947-Slave_systems_identification-Sensore dell'umidit� dell'aria interna,indisponibile ,6
ENG141684-SFT271966-Slave_systems_identification-Riscaldamento zona della testa a sinistra,indisponibile ,6
ENG141684-SFT271967-Slave_systems_identification-Riscaldamento zona della testa a destra,indisponibile ,6
ENG141684-SFT272065-Slave_systems_identification-Ventola 1 dello schienale del sedile anteriore sinistra,indisponibile ,6
ENG141684-SFT272067-Slave_systems_identification-Ventola 1 della seduta del sedile anteriore sinistro,indisponibile ,6
ENG141684-SFT272069-Slave_systems_identification-Ventola 1 dello schienale del sedile anteriore destro,indisponibile ,6
ENG141684-SFT272071-Slave_systems_identification-Ventola 1 della seduta del sedile anteriore destro,indisponibile ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,SMLS ,4
ENG116588-Sonderfunktionen-,non liberat. ,4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1,non montat. ,4
ENG141635-ENG116658-Regolazione degli specchietti-Funk Spiegelanklappen,attiv. ,5
ENG141635-ENG116665-Regolazione degli specchietti-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Regolazione degli specchietti-Menuesteuerung Funk Spiegel anklappen,attiv. ,5
ENG141635-ENG116657-Regolazione degli specchietti-Menuesteuerung Spiegelabsenkung,attiv. ,5
ENG141635-ENG116659-Regolazione degli specchietti-Menuesteuerung synchrone Spiegelverstellung,attiv. ,5
ENG141635-ENG126841-Regolazione degli specchietti-Profilfunktion fuer Anklappung der Aussenspiegel,attiv. ,5
ENG141635-ENG126610-Regolazione degli specchietti-Signalisierung_Spiegelanklappung,attiv. ,5
ENG141635-ENG116650-Regolazione degli specchietti-Spiegelabsenkung bei Rueckwaertsfahrt,attiv. ,5
ENG141635-ENG133411-Regolazione degli specchietti-Spiegelanklappen_bei_Wiederverriegelung,attiv. ,5
ENG141635-ENG116656-Regolazione degli specchietti-Spiegelverstellung Synchron,attiv. ,5
ENG153700-ENG154515-Devioguida-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Devioguida-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Devioguida-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Devioguida-Zeit_erkennung_fahrt_f�r_P_plausibel,10.0 min,10
ENG153700-ENG154829-Devioguida-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0,0.0 lx,10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1,8.0 lx,10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2,50.0 lx,10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3,80.0 lx,10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4,100.0 lx,10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0,6.0 ,10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1,6.0 ,10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2,20.0 ,10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3,50.0 ,10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4,100.0 ,10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0,0 ms,22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0,100.0 %,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10,0.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,non attiv. ,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung,attiv. ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0,0 ,22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1,50 ,22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10,0 ,22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2,100 ,22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3,200 ,22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4,253 ,22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5,0 ,22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6,0 ,22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7,0 ,22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8,0 ,22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9,0 ,22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0,0 lx,22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10,0 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 ,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 ,22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6,0 lx,22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7,0 lx,22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8,0 lx,22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9,0 lx,22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0,0 ms,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0,0 lx,8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1,8 lx,8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2,50 lx,8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3,500 lx,8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0,100.0 ,8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1,100.0 ,8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2,100.0 ,8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3,100.0 ,8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0,0 lx,8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1,8 lx,8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2,50 lx,8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0,6.0 ,8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1,6.0 ,8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2,100.0 ,8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3,100.0 ,8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 %,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 %,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 %,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 %,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 %,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 %,12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0,10 ,12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1,10 ,12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2,100 ,12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3,150 ,12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4,220 ,12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5,253 ,12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0,0 lx,10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1,8 lx,10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2,200 lx,10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3,300 lx,10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4,500 lx,10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0,16.0 ,10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1,16.0 ,10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2,100.0 ,10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3,100.0 ,10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4,100.0 ,10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0,0 lx,10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2,220 lx,10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3,300 lx,10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4,500 lx,10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0,6.0 ,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0,0 ,12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1,10 ,12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4,220 ,12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5,253 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5,100.0 %,12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0,0 lx,8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1,8 lx,8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2,50 lx,8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3,500 lx,8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0,6.0 ,8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1,6.0 ,8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2,100.0 ,8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3,100.0 ,8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0,0 lx,8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1,8 lx,8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2,50 lx,8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3,500 lx,8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0,100.0 ,8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1,100.0 ,8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2,100.0 ,8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 %,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 %,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 %,6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0,0.0 %,6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1,50.0 %,6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2,100.0 %,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1020 lx,12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 ,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG141632-ENG116647-Tetto scorrevole-SAD Komfort oeffnen,attiv. ,4
ENG141632-ENG116646-Tetto scorrevole-SAD Komfort schliessen,attiv. ,4
ENG141632-ENG116645-Tetto scorrevole-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Tetto scorrevole-Schiebedachmodul_MD_1,montat. ,4
ENG141632-ENG141971-Tetto scorrevole-Schiebedachmodul_MD_3,non montat. ,4
ENG141632-ENG141972-Tetto scorrevole-Schiebedachmodul_MD_Rollo,non montat. ,4
ENG141632-ENG142022-Tetto scorrevole-Verortung Schiebedachmodule,LIN ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,attiv. ,9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,non attiv. ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,non attiv. ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,non montat. ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,attiv. ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,attiv. ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlie�en,attiv. ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,non attiv. ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,non attiv. ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,sempre ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,sempre ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,non montat. ,9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,non attiv. ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,attiv. ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,attiv. ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,attiv. ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlie�en via Funkfernbedienung,attiv. ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlie�en via Kessy,attiv. ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlie�en via Schlie�zylinder,attiv. ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,non attiv. ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,non attiv. ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,non montat. ,9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB,non attiv. ,7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,non attiv. ,7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,attiv. ,7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,attiv. ,7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,non attiv. ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,non montat. ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,non montat. ,7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion,non attiv. ,7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,attiv. ,7
ENG141651-ENG115755-ZV allgemein-Notschlie�funktion,attiv. ,7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung,non attiv. ,7
ENG141651-ENG141957-ZV allgemein-Frequenza radio,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,non montat. ,7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck,attiv. ,3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln,attiv. ,3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,non attiv. ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,non attiv. ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,non attiv. ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren,attiv. ,4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,non attiv. ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,non attiv. ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,attiv. ,7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,non attiv. ,7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,non attiv. ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,non montat. ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,non attiv. ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,non attiv. ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,si ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Comando contatto ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,non attiv. ,7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang,no ,7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel,attiv. ,7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen,non attiv. ,7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp,Posizionatore portellone a 1 o 2 scatti ,7
ENG141681-IDE02021-ZV Komfort-Chiusura comfort,attiv. ,8
ENG141681-IDE02022-ZV Komfort-Apertura comfort,non attiv. ,8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten,si ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,attiv. ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,attiv. ,8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit,600 s,8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus,attiv. ,8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,attiv. ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,attiv. ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,attiv. ,8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global,attiv. ,8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer,non attiv. ,8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,non attiv. ,8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,once ,8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,non attiv. ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,non attiv. ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,non attiv. ,8
ENG141652-ENG141999-ZV T�rkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142043-ZV T�rkonfiguration-HFT_Invertierung_Drehfallensignal,nicht invertiert ,5
ENG141652-ENG142039-ZV T�rkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,non montat. ,5
ENG141652-ENG142038-ZV T�rkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,non montat. ,5
ENG141652-ENG142001-ZV T�rkonfiguration-Schiebetuer_links,no ,5
ENG141652-ENG142002-ZV T�rkonfiguration-Schiebetuer_rechts,no ,5
ENG141652-ENG142041-ZV T�rkonfiguration-Schiebetueren_Crafter,non montat. ,5
ENG141652-ENG142244-ZV T�rkonfiguration-Schiebetuerschloss_direkt_BCM,lato guida ,5
ENG141652-ENG116631-ZV T�rkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,non attiv. ,5
ENG141652-ENG142000-ZV T�rkonfiguration-Schlosstyp_NAR,no ,5
ENG141652-ENG141959-ZV T�rkonfiguration-Viertuerer,si ,5
Tempo trascorso: 02:10
Cuzoe
Please start a new topic. And I hope this does not come across rudely, but you will get more help here if your posts and autoscans/ad-maps are in English. I did use google translate on your post, and you are incorrect about the difference between pre-facelift and facelift. Facelift BCM has no long coding, all 0's which is the first and most obvious difference. Then another difference is the pre-facelift BCM does not have adaptations channels ColorList or ColorList LIN.
My pre-facelift BCM is HW 5Q0-937-087-S, while my facelift BCM is 5Q0-937-084-CG
This is different hardware part numbers. You mention flashing which is software, not hardware.
And a quick partial answer to your questions, until we meet in another topic... I have not mapped any GCA files or inserted Passat GCA. Read through Post #5.
IDE11477-ENG128655-Parametri illuminazione abitacolo-p_ambienteumfang_mehrfarbig_HMI, 00000101 This is wrong, should be 00001101 if you want front strip
Also all of these values are set to 0, you need to input RGB Colors here...
Code:
IDE12412-ENG154526-Luci soffusi: lista colori LIN-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154527-Luci soffusi: lista colori LIN-Blauwert_Farbe_10_lin,0 ,30
IDE12412-ENG154537-Luci soffusi: lista colori LIN-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-Luci soffusi: lista colori LIN-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-Luci soffusi: lista colori LIN-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-Luci soffusi: lista colori LIN-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-Luci soffusi: lista colori LIN-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-Luci soffusi: lista colori LIN-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-Luci soffusi: lista colori LIN-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-Luci soffusi: lista colori LIN-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-Luci soffusi: lista colori LIN-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-Luci soffusi: lista colori LIN-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-Luci soffusi: lista colori LIN-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-Luci soffusi: lista colori LIN-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-Luci soffusi: lista colori LIN-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-Luci soffusi: lista colori LIN-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-Luci soffusi: lista colori LIN-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-Luci soffusi: lista colori LIN-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-Luci soffusi: lista colori LIN-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-Luci soffusi: lista colori LIN-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-Luci soffusi: lista colori LIN-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-Luci soffusi: lista colori LIN-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-Luci soffusi: lista colori LIN-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-Luci soffusi: lista colori LIN-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-Luci soffusi: lista colori LIN-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-Luci soffusi: lista colori LIN-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-Luci soffusi: lista colori LIN-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-Luci soffusi: lista colori LIN-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-Luci soffusi: lista colori LIN-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-Luci soffusi: lista colori LIN-Rotwert_Farbe_9_lin,0 ,30
There are two color lists... lista colori and then also lista colori LIN... you need both... reference here from daChillout.
Lista colori determines the color options that will show in your screen
Lista colori LIN is the RGB output to the LED's (which display colors differently than your screen)
