RGB Ambient Lighting for Mk7 and Mk7.5
Genebaby
Australia
2020 Golf GTI
This guy is having some adventures. Was the glove box trim this difficult for you?
I believe there may be more video as the last was just released yesterday and he hasn't shown everything yet.
Genebaby
Australia
2020 Golf GTI
It gives you a good indication of how well it's connected.
I think I was looking at this channel when I put my rear USB's in and didn't look at anything else.
Riddick20
Parma - Italy
update.
I made all the connections to have the lights in the doors in OEM mode.
I then connected to the BCM and sent the wiring to the 4 doors and to the passenger glove box.
the colleagues were these:
red wire: power supply under 10 amp fuse
black wire: ground
purple / white wire (in my case): to the LIN line of the BCM, that is pin 29 of the C connector
at this point I only need the coding to do with VCDS to activate the door lights.
I state that I already have the 30 colors working on mib and digital tacho.
does anyone know how to help me find the codes and adaptations to do with VCDS to activate the lights in the doors managed by MIB?
Thank you.
crngiar auto
shenzhen,guangdong
skoda
更新。
我进行了所有连接,以便在 OEM 模式下将灯安装在门上。
然后我连接到 BCM 并将接线发送到 4 个车门和乘客手套箱。
同事是这些:
红线:10安培保险丝下的电源
黑线:地线
紫色/白色线(在我的情况下):到 BCM 的 LIN 线,即 C 连接器的引脚 29
在这一点上,我只需要与 VCDS 相关的编码来激活门灯。
我声明我已经有 30 种颜色用于 mib 和数字转速计。
有谁知道如何帮助我找到与 VCDS 相关的代码和改编,以激活 MIB 管理的门中的灯?
谢谢你
1、使用ODIS诊断仪进入09中央电控单元的访问权限:31347或48396
2.选择匹配功能
[LO]_Farbwahl_ueber_HMI 改为“未安装”(其实只需要修改这个参数,如下检查即可)
[LO]_Ambientemenue mit globalem aus 更改为“激活”
[LO]_Ambientemenue?mitalle Zonen 更改为“激活”
[LO]_Ambient_Farbliste_HMI 更改为“激活”
[LO]_Frei_Farbwahl_ueber_HMI 更改为“激活
dvw.r
Belgium
MK7.5 R
Well hello 👋
I just created an account to try to help you guys out.
I did the mod but with OEM parts except for the light guides in the dash an rear doors, so I upgraded my BCM.
To be honest I don't have the time to really write a how to but I will try if the demand is high.
So to help you out with the coding:
pa_verbauinfo_gruppe_1 ----- multicolor
pa_lichtfunktion_gruppe_1 ----- Door
pa_korrekturfaktor_gruppe_1 ----- 1
pa_einzeladresse_slave_1 ----- 1
pa_verbauinfo_slave_1 ----- installed
pa_fehlerort_slave_1 ----- 0
pa_einzeladresse_slave_2 ----- 2
pa_verbauinfo_slave_2 ----- installed
pa_fehlerort_slave_2 ----- 0
pa_einzeladresse_slave_3 ----- 3
pa_verbauinfo_slave_3 ----- installed
pa_fehlerort_slave_3 ----- 0
pa_einzeladresse_slave_4 ----- 4
pa_verbauinfo_slave_4 ----- installed
pa_fehlerort_slave_4 ----- 0
pa_einzeladresse_slave_5 ----- 0
pa_verbauinfo_slave_5 ----- not installed.
pa_fehlerort_slave_5 ----- 0
Farbausgabe Tuertafelbeleuchtung nicht berechnen ----- not an act. (turn off the prohibition on regulation)
Helligkeit_Tuertafelbeleuchtung_nicht_berechnen ----- not active. (turn off the prohibition on adjustment)
Tuertafelbeleuchtung mehrfarbig ----- act. (strip in the door is colored)
That's just for the door-strips. I don't know if you need more, because I don't know what you already did.
If you could provide me an Admap @Riddick20 , I can check what else u need if you want. :)
Kind regards
dvw-r
Riddick20
Parma - Italy
Well hello 👋
Kind regards
dvw-r
Thank you very much. @dvw-r
Unfortunately, however, despite the encodings of my BCM seem correct, the 5 lights (4 doors + glove compartment) did not work.
I am attaching the exchange of the adaptations of my BCM ... maybe you see what is wrong.
Consider that I made the OEM connections, so:
positive
mass
lin to pin 29 connector c
  • adpmap-09-5Q0-937-084-DD_WVWZZZAUZEW144891-20210822-1822.zip
dvw.r
Belgium
MK7.5 R
@Riddick20 Everything looks fine.
Did you use OEM LEDS or the Chinese ones? I don't know the addresses of the Chinese parts of course.
What you could try is to enable all slaves and watch what happens.
So,
and so on
pa_einzeladresse_slave_10 ----- 10
And the connections are fine too.
Is the 12V connected to terminal 30 (permanent positive)?
Kind regards
dvw-r
dvw.r
Belgium
MK7.5 R
@Riddick20 not to Fuse 30 but to a fuse that's permanent switched.
They need 12V all the time, not only when the ignition is switched to ON. I added an extra fuse.
But let's assume for now that you did that correct. Can you try to enable the other slaves?
If they used the dashboard LED it's address 5, so u could try to code this as well:
pa_einzeladresse_slave_5 ----- 5
pa_verbauinfo_slave_5 ----- installed
