BiH_GTI
- St. Louis, MO
I just made some inside the car sounds clips.
https://youtu.be/4a4SmM4zxWo
Is there much drone at cruising speed around 70+? I didn't really hear it. But it may not have picked it up. Sounds damn good though! ThanksI just made some inside the car sounds clips.
Sent from my XT1650 using Tapatalk
I'm curious if a vibrant resonator would cure that [emoji2369][emoji2369][emoji2369]70 to 75 is ok not as bad as 75 to 80 under load
It's coming today. Just need to find the time to put it in. Probably this weekend.
I'm planning on making a quick before and after video to show the difference.
I took a before and after run before and after the vibrant...
It's better, for sure. Damn armrest still vibrates a little. Going to have to dynamat it or something. Overall it's a bit more tame and civilized.
Gotta get the videos merged edited or whatever. Anybody with the ability to do so, lmk. Otherwise, I'll be fumbling with it myself and I'll get them up eventually.
Sent from my Nexus 5X using Tapatalk
Nothing touching or even close. You can get a hand around each section and coupler. Besides where it goes under the rear subframe, where its close but not making contact.
I reinstalled everything today when I cut the reducer off the downpipe. I worked from front to back, fitting each section. Clear on all sides. My car is just producing this low frequency resonance. The vibrant absolutely cut it down a bit, but its still there's little.
I put some time and effort into the rear exhaust tunnel covet today too. My determination is that the little hotdog resonator is slightly too large diameter in that area. Had it been a straight pipe there, it would fit. Still not sold on trimming that part. I might yank the resonator and drop a straight pipe in they're so I can refit the cover.
The secret to getting the tips aligned, vertically, is the twist on the piece next to the drivers rear wheel. A little left or right and it sends the tips up or down. For anyone fighting that battle. That's the cliffnotes on it.
Sent from my SM-T580 using Tapatalk
I removed the long res and put the vibrant there. I'll post the pic tonight of what i removed and what i added. I also cut a few inches off the CTS DP (where the taper is) and replaced it with straight 3" going to the vibrant resonator.
For the adjustment of the tips, you have to loosen the last clamp (before the split to the mufflers), at the rear, and the one between the two hotdog resonators. Then the (sort of s shaped) section can be rotated clockwise or counter clockwise. You twist it so that the bend is closer to the car or closer top the ground. This concurrently moves the tips up and down. Once you get it here you want it, tighten the clamps.
Anyone running this exhaust on a factory DP car? Curious as to what the sound is.
