Okay, PA, a/c isn't really an option this time of year for many of us. I don't really know what's different with the coding for ECS fully off, but something about the throttle mapping seems to be more linear and rev matching is much more intuitive.Part it out.
Your revs will drop faster with the AC on, so you have to drive it a little bit differently. But if you are driving aggressively, why is your AC on?
Part it out.
Another vote for AC. It's 90 degrees out right now, and muggier than Poseidon's balls. I'm pretty sure that if I get a track day in this year, I'm still going to have the AC on, if just to avoid heat stroke with the helmet.Your revs will drop faster with the AC on, so you have to drive it a little bit differently. But if you are driving aggressively, why is your AC on?
Is it possible that your BMW engines were larger displacement? My manual BMW's have displayed some a/c lag, but less than smaller displacement engines.AC affects engine revs on every MT car I've owned except BMW. The AC had no effect on the BMW's rpm or how it drives. I never looked into why it's different but I wish every manufacturer would do the same.
Part it out.
Heel+toe should solve that. Use the ball of your foot. Left side of the ball to apply the brake, then rotate your ankle and use the right side of the ball to blip the throttle.How do you even throttle blip downshift these cars? The brake pedal is too far from the gas pedal, I even got a gas pedal spacer and its still very awkward to say the least....and I wear size 12 shoes.
