Retrofitting Lane assist camera without changing windshield?
Cuzoe
And if you don't care about using traffic signs, if you want a super lane tracking system, using a 2Q0980653 type camera will be much, much better. I will do that on the weekend
I've been reading about these 2Q0 cameras. These are the ones being installed with a 3d printed adapter, yes?
How does losing traffic sign recognition impact pACC? Or does it?
doctor
VAG
Definetely you will losing the pACC. But swap code can solve that (2Q camera needs swap codes) .
modesto93
Italy
Seat Leon 1.4 TGI 17
Hi everyone, I have enjoyed reading many pages about this project. I am in Italy and you will excuse me if my English is not perfect. I would like to add the camera for the lane assistant, I have a 2017 Seat Leon with ACC. the camera code should be 3q0980654 correct me if i'm wrong. There are various versions where the letter changes at the end, the last should be H. I only have VCDS. Is there anyone who's done with this software? I calibrated the ACC after having had an error and it proved to be reliable. After I should think about how to fix the camera and I really like projects where the camera is separated from the brain with 20cm cable seems like a good idea. Can you give me some more advice?
doctor
VAG
Change windshield, better.
dawcioral
PL
MK7.5
Hi. I replaced the windshield in my car and set up a 3qd980654 camera. So far I had a mirror with light assist. I do not want to replace the mirror with those without a camera, now I have this mirror on.
Will you help me set the encoding so that there are no errors - Encoding light assist from the mirror camera to the A5 camera?
Nuje
Island near Vancouver
2015 Sportwagen TDI
Do you realize that there is not plastic trim pieces that will fit around your mirror that has light-assist and also cover up the A5 camera?
I was in same situation and tried a few different things, but in the end, just bought the new mirror (ebay).
tn@
Japan
Golf mk7
for those who have used the 3Q0 camera which extension did you use and what length
hai, I tried to extend the 3Q camera by 400mm but it was impossible because of an error. I'm using black film and double sided tape to attach the front sheeld.
dawcioral
PL
MK7.5
I was planning to buy these parts, are you sure it will not fit this mirror?
3G085863482v
3G085863382v
5G0868437AY20
Nuje
2015 Sportwagen TDI
3G085863482v
3G085863382v
5G0868437AY20
All I can say is that on my car (Mk7 GSW) that came without Lane Assist, but had High Beam Assist camera mounted to mirror, those trim pieces would not fit.
To prove that point, the 3G085863482v part (and its mate) does not have a hole for the camera to "see" through. Even without the HBA camera mounted to my original mirror, the trim pieces did not work.
xabhax
15 GTI
Some Chinese company is selling a mount for the camera that is 3m taped to the windshield. I'll try and find a link.
dawcioral
PL
MK7.5
After adding the lane assist camera, I still have one red error in the A5 module - U112100 - Databus missing message. Communication is missing, but I don't know with what. Below I paste the coding of the 3QD980654 camera, I hope you will find some error here.
00 03 07 00 00 00 04 01 00 22 23 54 C1 50 A9 00 98 00 0E 23 00 20
My car: MK7.5 2.0TDi DSG, Led Mid, LightAssist(in mirror before), PLA.
xabhax
15 GTI
Can you post a full scan?
dawcioral
PL
MK7.5
01 Engine
Opis sytemu: R4 2.0l TDI
Numer oprogramowania: 04L906026RJ
Wersja oprogramowania: 4381
Numer jednostki sterującej: 04L907309R
Wersja jednostki sterującej: H24
Nazwa ODX: EV_ECM20TDI01104L906026RJ
Wersja ODX: 004001
Długie kodowanie: 01250032036405082000
Kody błędów:
Nie znaleziono kodów błędów
02 Transmission
Opis sytemu: GSG DQ381
Numer oprogramowania: 0GC300042G
Wersja oprogramowania: 1638
Numer jednostki sterującej: 0GC927711G
Wersja jednostki sterującej: H06
Nazwa ODX: EV_TCMDQ381061
Wersja ODX: 001
Długie kodowanie: 0014
Kody błędów:
03 Brakes
Opis sytemu: ESC
Numer oprogramowania: 5Q0614517CF
Wersja oprogramowania: 0513
Numer jednostki sterującej: 5Q0614517AD
Wersja jednostki sterującej: H25
Numer seryjny: 61497000000086
Nazwa ODX: EV_Brake1UDSContiMK100IPB
Wersja ODX: 036010
Długie kodowanie: 04FA62A124200970477C060040C62920462490E26002947338625078C222430000000012121212B835351919323200
Kody błędów:
08 Air Conditioning
Opis sytemu: Climatronic
Numer oprogramowania: 5G0907044CF
Wersja oprogramowania: 1801
Numer jednostki sterującej: 5G0907044CF
Wersja jednostki sterującej: H04
Nazwa ODX: EV_ACClimaBHBVW37X
Wersja ODX: 006145
Długie kodowanie: 02020104202410011105000200101022
Kody błędów:
09 Central Electrics
Opis sytemu: BCM PQ37BOSCH
Numer oprogramowania: 5Q0937086BL
Wersja oprogramowania: 0242
Numer jednostki sterującej: 5Q0937086BG
Wersja jednostki sterującej: 034
Numer seryjny: 86582105170118
Nazwa ODX: EV_BodyContrModul1UDSBosc
Wersja ODX: 018001
Podsystemy:
Opis sytemu: WWS 170501
Wersja oprogramowania: 0551
Wersja jednostki sterującej: 043
Numer seryjny: 170516230330
Długie kodowanie: 0E4DDD
Opis sytemu: RLHS
Wersja oprogramowania: 0105
Wersja jednostki sterującej: 042
Numer seryjny: S8Y17M05D31H14M55S07
Długie kodowanie: 00A8EE
Kody błędów:
13 Adaptive Cruise Control
Opis sytemu: ACC BOSCH MQB
Numer oprogramowania: 5Q0907572J
Wersja oprogramowania: 0654
Numer jednostki sterującej: 3QF907572
Wersja jednostki sterującej: H10
Nazwa ODX: EV_ACCBOSCHVW416
Wersja ODX: 002006
Długie kodowanie: 33196761F5FFCF28949C810580400600000000000000000000
Kody błędów:
15 Airbag
Opis sytemu: AirbagVW21
Numer oprogramowania: 5Q0959655BJ
Wersja oprogramowania: 0336
Numer jednostki sterującej: 5Q0959655BJ
Wersja jednostki sterującej: 005
Numer seryjny: 003VWR2ZYF4B
Nazwa ODX: EV_AirbaVW20SMEVW37X
Wersja ODX: 002158
Długie kodowanie: 98CCC000000000005C0000CF000800000065
Podsystemy:
Opis sytemu: BeltPretRevFL
Wersja oprogramowania: 0350
Wersja jednostki sterującej: H37
Numer seryjny: 34169667E24051740065
Długie kodowanie: 333135
Opis sytemu: BeltPretRevFR
Numer seryjny: 34169668E30051750946
Opis sytemu: SideSensor_Df
Wersja oprogramowania: 0887
Wersja jednostki sterującej: 001
Numer seryjny: 357000000007D1111422
Długie kodowanie: 2D2D2D
Opis sytemu: SideSensor_Pf
Numer seryjny: 35800000000F91BCF32+
Opis sytemu: SideSensor_Dr
Wersja oprogramowania: 6149
Wersja jednostki sterującej: 000
Numer seryjny: 3510001BD25975E63223
Opis sytemu: SideSensor_Pr
Numer seryjny: 3520001BF25975E24627
Opis sytemu: FrontSensor_D
Numer seryjny: 3550001A525A6984215
Kody błędów:
16 Steering Column
Opis sytemu: Lenks.Modul
Numer oprogramowania: 5Q0953521P
Wersja oprogramowania: 0235
Numer jednostki sterującej: 5Q0953569A
Wersja jednostki sterującej: 075
Numer seryjny: 20170529201116
Nazwa ODX: EV_SMLSVALEOMQB
Wersja ODX: 001016
Długie kodowanie: 0410
Kody błędów:
17 Dashboard
Opis sytemu: KOMBI
Numer oprogramowania: 5G1920751C
Wersja oprogramowania: 0310
Numer jednostki sterującej: 5G1920751C
Wersja jednostki sterującej: 302
Nazwa ODX: EV_DashBoardVDDMQBAB
Wersja ODX: 009060
Długie kodowanie: 07A421086F84000801886A031401000080000000
Kody błędów:
19 Gateway
Opis sytemu: GW MQB High
Numer oprogramowania: 3Q0907530G
Wersja oprogramowania: 5304
Numer jednostki sterującej: 3Q0907530C
Wersja jednostki sterującej: 518
Numer seryjny: 24051710521962
Nazwa ODX: EV_GatewNF
Wersja ODX: 013023
Długie kodowanie: 030100045F086800FA0002481C0F00010001070000000000000000000000
Podsystemy:
Opis sytemu: J367-BDMHella
Wersja oprogramowania: 9070
Numer seryjny: 5807543904
Opis sytemu: E221__MFL-DC1
Wersja oprogramowania: 0040
Wersja jednostki sterującej: H17
Numer seryjny: 46170001414990087214
Długie kodowanie: 2DFFFF
Kody błędów:
42 Driver Door
Opis sytemu: TSG FS
Numer oprogramowania: 5Q4959593E
Wersja oprogramowania: 0032
Numer jednostki sterującej: 5Q4959593B
Wersja jednostki sterującej: 011
Numer seryjny: 0000259586468
Nazwa ODX: EV_DCUDriveSideEWMAXCONT
Wersja ODX: 006001
Długie kodowanie: 003B0320D000028000001000
Podsystemy:
Opis sytemu: Fond FHSG DRV
Wersja oprogramowania: 0002
Wersja jednostki sterującej: 007
Numer seryjny: 00000000000006980381
Długie kodowanie: 010000
Kody błędów:
44 Steering Assistance
Opis sytemu: EPS_MQB_ZFLS
Numer oprogramowania: 5Q0909144T
Wersja oprogramowania: 1072
Numer jednostki sterującej: 5Q0909144R
Wersja jednostki sterującej: 129
Nazwa ODX: EV_SteerAssisMQB
Wersja ODX: 013144
Długie kodowanie: 1307
Kody błędów:
4B Multifunction Module
Opis sytemu: FCM MQB Low
Numer oprogramowania: 3Q0907338
Wersja oprogramowania: 0286
Numer jednostki sterującej: 3Q0907338
Wersja jednostki sterującej: 002
Numer seryjny: 23051710520939
Nazwa ODX: EV_MultiModulContiVW48X
Wersja ODX: 001010
Długie kodowanie: 000000070100194A00000141020000000000000000000000000000000000
Kody błędów:
52 Passenger Door
Opis sytemu: TSG BFS
Numer oprogramowania: 5Q4959592E
Numer jednostki sterującej: 5Q4959592B
Numer seryjny: 0000260331565
Nazwa ODX: EV_DCUPasseSideEWMAXCONT
Wersja ODX: 006001
Długie kodowanie: 003B0120DE00028000801000
Podsystemy:
Opis sytemu: Fond FHSG PSG
Numer seryjny: 00000000000005889879
Długie kodowanie: 090000
Kody błędów:
5F Multimedia
Opis sytemu: MU-S-N-ER
Numer oprogramowania: 3Q0035864C
Wersja oprogramowania: 0475
Numer jednostki sterującej: 3Q0035864C
Wersja jednostki sterującej: H41
Numer seryjny: VWZAZ2T1379780
Nazwa ODX: EV_MUStd4CTSAT
Wersja ODX: 001022
Długie kodowanie: 02731201000000004111000200080A231F0500F401200500CF
Podsystemy:
Opis sytemu: ABT_Std-2_Nav
Wersja oprogramowania: 8304
Wersja jednostki sterującej: 381
Numer seryjny: VWZ6ZHY2742371
Opis sytemu: ECE AS 23/24
Wersja oprogramowania: 2010
Wersja jednostki sterującej: ---
Numer seryjny: --------------------
Kody błędów:
B200087 - Control module Software incompatible
static
Date: 2023-01-08 18:54:31
Mileage: 163226 km
Priority: 6
Malfunction frequency counter: 1
Unlearning counter: 35
Dynamic environmental data: 02869410030401016F6E6C696E6500
76 Parking Assistance
Opis sytemu: PLA 3.0 12K
Numer oprogramowania: 5QA919298C
Wersja oprogramowania: 0045
Numer jednostki sterującej: 5QA919298A
Wersja jednostki sterującej: H07
Numer seryjny: 00030841761714501569
Nazwa ODX: EV_EPHVA2CAU3700000
Wersja ODX: 009037
Długie kodowanie: 0271163851
Kody błędów:
A5 Driver Assistance
Opis sytemu: MQB_B_MFK
Numer oprogramowania: 3QD980654
Wersja oprogramowania: 1272
Numer jednostki sterującej: 3Q0980654A
Wersja jednostki sterującej: H08
Numer seryjny: 02061841K10540
Nazwa ODX: EV_MFKBoschMQBB
Wersja ODX: 001001
Długie kodowanie: 000307000000040100022354C150A90098000E230020
Kody błędów:
static
Date: 2023-01-08 18:52:15
Mileage: 163226 km
Priority: 6
Unlearning counter: 38
Control module temperature: 31 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 11.9 V
Outside air temperature: 4.0 °C
System run time: 258.2 s
Status of camera: operational
Engine_Running_Info: 0
MID: 020B
Software_Info_1: 1
Software_Info_2: 2
Software_Info_3: 7
Software_Info_4: 2
D6 LED Module Left
Opis sytemu: LED1L
Numer oprogramowania: 7P5941591AD
Wersja oprogramowania: 0005
Numer jednostki sterującej: 7P5941591A
Nazwa ODX: EV_LED_PLUS_L_KEBODAVW416
Wersja ODX: 001003
Kody błędów:
D7 LED Module Right
Opis sytemu: LED1R
Nazwa ODX: EV_LED_PLUS_R_KEBODAVW416
Wersja ODX: 001003
Kody błędów:
