VCDS has the option to proceed static calibration for the front assist camera.
I cannot confirm it 100% works.
I have tried to calibrate with VCDS, but my camera was somehow faulty and it didn't work even with ODIS.
So finally I have bought another camera and calibrated with ODIS, as I had it already.
Here is the procedure for the VCDS I have for the 5Q0 camera.
1. First, have a good target and correct setup.
In VCDS there is an option to search target, but if it pass it does not mean the setup (height, distance, level, etc) is correct! It just recognized the screen in front of the camera.
2. Go to the camera module:
[A5-Frt Sens. Drv. Assist]
3. Go to the security and enter the code
[Security Access - 16] > Enter shown code (20103)
4. Go to the adaptation and enter correct values
[Adaptation - 10]
Body height wheel house edge-Body height left front wheel house edge > Enter value > [Do It!]
Body height wheel house edge-Body height right front wheel house edge > Enter value > [Do It!]
Body height wheel house edge-Body height left rear wheel house edge > Enter value > [Do It!]
Body height wheel house edge-Body height right rear wheel house edge > Enter value > [Do It!]
Distance to calibration field > Enter 1500 > [Do It!]
5. Go to basic settings and start the calibration process (it shouldn't take long)
[Basic Settings - 04]
Static calibration (customer service)
If everything goes correct in the advanced measuring values there will be info as follow:
[Show Measuring Data]
IDE00322 Status of basic setting -> not active
IDE02057 Dynamic calibration: status -> active
If procedure fails there is no information why and this is the worst in VCDS. However maybe the static calibration status in the measured data shows more info, I haven't tried it.
You have to try until it pass. I have tried many times, but when finally found correct setup it was passing almost every time I have performed it. And I have tried many times as I had faulty camera and seen no results.
All the coding should be completed and wires has to be connected before calibration. There should be only one fault present [No basic settings].
There is additional info that may help with setup, but it is not 100% required:
- Charger connected > Doors must be closed > Maybe hood closed (not mentioned in erwin)
- No persons in the car > Min. 50% fuel in the tank > No light reflections in the room
- Move front wheels to straight-ahead position.
One information than can be useful and I wasn't aware.
The assistance camera should start to do its job whenever the static calibration is successfully completed. Do not need the dynamic calibration to finish (of course if all angles are within the limits). In my case the dynamic calibration is still active and camera is working correctly.
Good luck.
Arek
