Ok, now i have every thing working.
Obd11 calibration:
1 place VAS6430 in wall 1,30m (from floor)
2 put car 1,5m away from board (from wall to the center of wheel ,measure in the floor .
3 measure 4 wheel arches .
All the next steps change search calibration target to Grundeinstellung
SEQUENCE IS IMPORTANT
OBD11:
4 - go to module A5 change type of diagnostic to vw
5 -go adaptation distance to calibration field 1500m confirm
6 -go adaptation body height wheel house edge
Type your measurments confirm
7 -go adaptation calibration target position
Just confirm
8 - go adaptation axel offset
Just confirm
9 - go basic configuration search calibration target
10 - go basic configuration initial online configuration
11 - go basic configuration Static calibration costumer service
12- change type of diagnostic to end of assembly line
13 - go basic configuration static calibration end of assembly line
Great stuff! It was the ADAPTATION channels I was missing (I'd tried originally in VCDS, but didn't get anywhere with that).Ok, now i have every thing working.
Obd11 calibration:
OBD11:
Just confirm
Just confirm
Thank you for posting the instructions / step-by-step; gonna try that first chance I get!
A dealer will refuse to do it on safety grounds.Can these cameras be properly calibrated at a dealers after its installed?
or because its not in the correct position would it fail?
scott
scott
Excellent work. I've been looking to see if I can do this without changing the windscreen and saw this post. Excellent - is it possible to get 3d file for this to help a fellow VWer?i made some changes to the bracket.
the air vents are tilt in order to send the air exactly into the camera little window in order to defroze this part...
the factory heater is there because theres no other way to do it...
this is invisible of course , is under the tint
This is a brilliant work. Where did you get the bit that holds hacked camera part? I have a passet - and my reverse mirror bracket only has small rain sensor hence there is no camera hold / and its angled hence can't fit the camera in.I have completed this in my 2018 polo AW.
scott
