Nuje
- Island near Vancouver
- 2015 Sportwagen TDI
The factory ACC (J428 in the diagram) has CAN wires (or/ws and or/br) that run to the TIUL from pins 5 and 6, respectively on the ACC radar. Pins 2 and 3 (or/gr and or/br) from ACC are the ones that run from pretty much directly from ACC radar unit to Front Assist camera (pins 8 and 2 on the 12-pin front camera connector); these are the ones I have to get through the firewall.If the ACC is factory then you just need to run the wires to the footwell and connect it to the TIUL coupling point, VW already ran wires from the acc to the footwell, all you need to do is connect the camera to these wires.
And like others have posted, there's a rubber grommet right near the big mass of wires going through the firewall - poke a hole in that, pull it through from underneath the battery tray (remove that first) - easy routing out to the front of the car.
