Retrofitting Lane assist camera without changing windshield?
Camarao69
Portugal
Ok, now i have every thing working.
Obd11 calibration:
1 place VAS6430 in wall 1,30m (from floor to black center dots)
2 put car 1,5m away from board (from wall to the center of wheel ,measure in the floor .
3 measure 4 wheel arches .
All the next steps change search calibration target to Grundeinstellung
SEQUENCE IS IMPORTANT
OBD11:
4 - go to module A5 change type of diagnostic to vw
5 -go adaptation distance to calibration field 1500m confirm
6 -go adaptation body height wheel house edge
Type your measurments confirm
7 -go adaptation calibration target position
Just confirm
8 - go adaptation axel offset
Just confirm
9 - go basic configuration search calibration target
10 - go basic configuration initial online configuration
11 - go basic configuration Static calibration costumer service
12- change type of diagnostic to end of assembly line
13 - go basic configuration static calibration end of assembly line
O have to say this works flawless the only thing i forgot o mention is the position of the board has to be 1,30 from floor to center black dots.
Just replaced my broken camera today that had the malfunction error.
Reaper1
Hi,
I ‘ve calibrated the camera again (twice this week to see if there are differences) and both calibrations with the board centered at 1,20m.
This went fine and no errors, yaw, pitch, roll are below 0.9 after calibraition the A5 has no errors,
Other than the previous calibrations where the "exceed limit" appeared within 10km driving, the dynamic calibration still shows "No Values Stored" after more than 100km driving.
"Dynamic calibration: details Passive: no values stored"
I've driven with the laptop connected and the Dynamics calibration shows sometimes Active for a few minutes, but the Dynamic Calibration Distance is still 0km after many days and km's driving.
Anyone knows what I'm doing wrong?
See values in the attachments
How are you driving?
After you see the car steers Itself properly you should let It drive by Itself as much as you can, Drive slower and every time the Lane assist light turns yellow move the steering wheel a bit.
It will take time, mine took months and around 400KM until It was done, But I guess It all depends on how much you drive.
gjburg2
Netherlands
Skoda Karoq
Thank you for the tips and suggestions, drove almost 500km and not one calibration kilometer was registered. Strange enough, sometimes it showed random a speed signs, but also when the sign shows 60km the dash shows a random limit like 120km.
After the first calibrations it instantly shows "Dynamic calibration exceed limits" at the first drive, and after later calibrations the dynamic km won't count and the signs are wrong. So probably static calibration image is good, but the moving images are affected by interference and camera signal got corrupted.
Due to the many calibrations, the FFC cable got also a bit crumpled, so I decided to re-ordered a 20cm FFC cable.
This time I put duct tape over the FFC cable to protect it.
Put everything back in the car, and I'm pretty experienced in calibrating now, :cool: so this was done in a few minutes.
And and and YES! 👍:D on the first drive it directly picked up the signs, and on the highway the Lane assist became green and shows yellow lines when steering also the self steering works instant!!
Don't know if it was a bad cable or bad connection,. Most important, calibrating has begun and every thing works.
modesto93
Italy
Seat Leon 1.4 TGI 17
guys which frontcamera should you take for Seat Leon 2017? As acc mounts the 5Q0 907 572 H .
5q0 or 3q0?
gjburg2
Netherlands
Skoda Karoq
5q0 or 3q0?
Hi, the 2016 Seat Leon has the 5Q0907572F and the A5 Camera 5Q0 980 653 G. When the 2017 model has a only a higher firmware variant it should work with 5Q0 980 653 G
You can probably also diable ACC with longcoding and have lane assist activated.
modesto93
Italy
On Aliexpress it is much easier to find the 3q0 which is sold in combination with the cable. The 5q0 cannot be found on sale with the cable needed for the connection…
