Retrofitting Lane assist camera without changing windshield?
mangio85
Italy
Passat b8 2015
I was driving from 11pm to 02am when the calibration error stopped for 60km
you can see live feed on OBD when calibration starts.
Really ?? ... but so it's always in constant control? Or does it have a range for which it can subsequently be considered closed? ... thanks
Reaper1
Hey, Dynamic calibration can take a while to calibrate properly, mine took over 200km to finish.
Only way to restart Dynamic calibration is to perform static calibration with the poster again.
There is a reason that Dynamic Calibration failed, the camera isnt aligned perfectly, Mine Has screws for adjustment as I've made the bracket myself Tho I Dont know why it fails in your case(Windshield replacement.)
To get Dynamic Calibration to work that's what I Did (Didn't Replace Windshield).
After Perfecting the Angles and getting them as close to 0 as possible I Go For A Long Drive, And While Driving I Stop After every 20KM( Only if the dynamic calibration didnt fail suddenly) And check the Offset(Live Data doesnt work for me that well).
Then I Just keep on driving, for a few weeks, adding more and more Kilometers to the dynamic calibration and waiting for it to calculate all 3 offsets, Once It Has Finished, you Should See: Passive Values Stored Under "Dynamic Calibration Status"
And You are done.
mangio85
Italy
Passat b8 2015
And You are done.
Well, you were very accurate, thanks. What are the real-time data to keep monitored? Maybe I take a screen and check.
I re-performed the static calibration and now for about 50 km I had no problems. I hope I'm on the right track.
Reaper1
In OBDeleven I Just Look For "Dynamic" And choose everything.
mangio85
Italy
Passat b8 2015
Reaper1
Thanks Reaper ...
What do you think about it?
Well, seems like it is done, As i Said, it says Passive values stored and you can see that it has calculated all the values.
Now just drive it a lot and it will just keep learning.
michelhendriks
netherlands
Audi A3 E-tron 2015
Hi everyone,
Thanks a lot for sharing your experiences (and frustrations ) on this forum it helped me a lot
just came back from a testdrive with a secondhand 5q camera taped to the windshield of my Audi A3 . Just before driving of I removed the basic setting error and I could drive "handsfree". So it can work.
Still in doubt of replacing the windshield , or do the ffc cable trick.
One question which I cannot the answer for is:
Why should I make a connection between my factory acc and the windshield camera? It also works without it.
Heard some rumours about increase of acc limit? it's in my car now 150km/h
When I look in obdeleven "dynamic calibration details"
I read distance driven with active dynamic calibration of 18466km. Is that normal?
super-andre21
Portugal
SEAT Ibiza
Thank you so much for your support...
I have an update. I managed to try another camera.
I think this is better.
What do you think? I enclose the results.
It's truth that we don't have to worry about databus errors before calibration ??
Thank you to all
Hi, how did you remove the acc module error?
I only have that error and i can not erase it, everything else is fixed but that error don't go away
Thank you
